Old 03-10-2009, 05:42 PM   #1
kickroqs
kickroqs is on a distinguished road
Minor Issues
Newbie here...'99 Alero 2.4... .................................................. ...................=An someone tell me which fuse and relay is the dome light to?
kickroqs is offline   Reply With Quote
Old 03-10-2009, 05:45 PM   #2
AGT
AGT's Avatar
Should be in the fuse panel on the left side when you open the door. labeled similar to INTLIGHT or DOME LIGHT
Have a good day
Old 03-11-2009, 10:53 PM   #3
kickroqs
Ok so I check the fuse and its good. The bulbs are good. What's should I try next?
Old 03-11-2009, 10:54 PM   #4
the switch
Old 03-11-2009, 10:59 PM   #5
Misuseofyou
Misuseofyou's Avatar
Misuseofyou is on a distinguished road
Did you check the fuse with your eyeball or a tester?
Misuseofyou is offline   Reply With Quote
Old 03-11-2009, 11:02 PM   #6
CactusWill
In my experience, it was the body control module. The seal at the bottom of the windshield was leaking and rain water was dripping into the electrical stuff. I sealed the window, and within a few weeks the bcm dried out and the interior lights started working again.
Old 03-25-2009, 04:37 PM   #7
kickroqs
Why is there a gap around my headlights?
Old 03-25-2009, 04:50 PM   #8
because GM failed at bumper design
Old 03-29-2009, 11:08 PM   #9
kickroqs
So is there anyway to reduce the gap?
Old 03-29-2009, 11:18 PM   #10
Uh, well, filling the area underneath the sagging portion would do it....?
Old 03-29-2009, 11:35 PM   #11
Use shims underneath the bumper to raise it up in certain areas.
