Old 03-25-2009, 02:15 PM   #1
99alerogirl
Female.
99alerogirl's Avatar
99alerogirl will become famous soon enough
what's next?
alright, so i'm where i wanted to be with my alero originally (as soon as i get my pcm back). i always told myself i wanted intake, exhaust, pcm, tint. now i have a job and want some input on where to go next. i was thinking of doing an appearance mod since all i have is tint and cleared corners... maybe some wheels or something. but where should i go next performance-wise?
here's what i've thought of, but i don't know if there's a logical order to go in:
-headers
-ported UIM and LIM along with the bigger TB (probably the competition set from wot-tech, planning on making my first trip to the track this year)
-OR the 3500 top swap, but i understand that this is probably a bit more expensive, and i don't exactly know what it requires.
-upgrade my exhaust to 2.5" mandrel bent pipe, possibly different muffler, mine's kinda raspy.. but that's a low priority
that's it, i don't know what else there is to do... obviously ported heads i guess? don't really know... let me know if i'm missing something easy. i do plan to turbo at SOME POINT in the future, but i figured building the engine up first is a good idea? and possibly investing in a new tranny before the turbo haha. any more suggestions? or which of these i should do first? keep in mind i have an extra 3400, so i've got some extra parts woohoo!
as far as appearance goes, i want to do wheels and a kit... probably the AAS kit. also eventually i wanna do something with paint, but that's also not a priority. OH and the razzi spoiler... sex. maybe the razzi kit rather than AAS if i go that route, don't know that the spoiler would look good with the AAS kit. not looking for anything too extravagant appearance-wise, more interested in the motor. thanks!
2012 Hyundai Veloster - new 40 MPG DD!!
1990 Nissan 300ZX Twin Turbo 5 speed - "Zeus"
2005 Nissan Titan SE King Cab 4x4 - gas guzzler
99alerogirl is offline   Reply With Quote
Old 03-25-2009, 02:19 PM   #2
light weight pulleys
Old 03-25-2009, 02:26 PM   #3
mfuller
If you are seriously planning to turbo it (not casually thinking, but really planning on it), don't waste your money on headers.
In fact, you really should decide now if you are going the forced induction route, or if you are staying NA - that will dictate a lot of your upgrade path.
Edit: Seeing as how the stock brakes are so woefully inadequate, I'd suggest upgrading them first...and it isn't too terribly expensive.
Old 03-25-2009, 02:29 PM   #4
99alerogirl
Female.
ok so no headers for a turbo? ha, i don't know much about it yet. i am planning on the turbo... just don't know what's needed. i know i'll have to have it custom fabbed, but what should i build up in the engine for more power before the turbo?
Old 03-25-2009, 02:34 PM   #5
99alerogirl
Female.
and there's not a s/c for the 3400 right? cause i'd probably rather do that i guess, but oh well!
Old 03-25-2009, 02:40 PM   #6
This should help
http://www.aleromod.com/forums/showthread.php?t=21593
Old 03-25-2009, 02:46 PM   #7
mfuller
You may want to do a bit of reading on how some of this stuff works before you get hip-deep in a project that ends up costing triple what you had budgeted.....
But without getting to deep into it, turbo manifolds (or headers) are quite a bit different than other headers. This is because the turbo is driven off the exhaust gasses, so the turbo needs to bolt directly to the manifold.
There are other supporting mods you can do for a turbo......better flowing heads and intake manifolds, etc. But what's good for a turbocharged engine is not necessarily optimal for an engine without a turbo, so you may want to wait until you have some idea of what exactly you want before you start buying parts.
Old 03-25-2009, 02:57 PM   #8
cliffordwoeller
You got beat by an Alero!
cliffordwoeller's Avatar
cliffordwoeller is on a distinguished road
Send a message via AIM to cliffordwoeller Send a message via MSN to cliffordwoeller Send a message via Yahoo to cliffordwoeller
so your building the engine up thats in the car ? and using the spare engine for replacement parts ? I want to get an extra engine and build that up then drop it in the ho, would that not be a better way of doing things if you were open to be patient ?
cliffordwoeller is offline   Reply With Quote
Old 03-25-2009, 03:45 PM   #9
Caboose73
Ya you should build up the spare engine and just take your time and plan everything out and definitely decide whether you want to go N/A or boost cause that makes a big difference in the direction of your build and the parts you have to buy.
Old 03-25-2009, 03:50 PM   #10
no reason to be N/A
boost
Old 03-25-2009, 03:57 PM   #11
Caboose73
no reason to be N/A
boost
X1,000,000 boost is the way to go
Old 03-25-2009, 04:10 PM   #12
cliffordwoeller
yeah I def want to boost but want to get a extra engine, now if anyone has one thats just completly trash and just want to get it off their hands I would def be interested in buying a 2.4
Old 03-25-2009, 04:35 PM   #13
You need to go s/c instead... =))))
Old 03-25-2009, 04:38 PM   #14
99alerogirl
Female.
thanks guys... really quick question... got my pcm back, but now my car will turn over and not start... security light's not on or anything. i need to leave soon so quick advice would help!!
Old 03-25-2009, 04:48 PM   #15
99alerogirl
Female.
nvm... i thought you only needed the relearn if the security light was blinking... mines on when my key is turned to on... waiting for the 10 minutes...
Old 03-25-2009, 04:50 PM   #16
Bad99Olds
New and Improved
Bad99Olds's Avatar
Bad99Olds is on a distinguished road
Send a message via AIM to Bad99Olds
thats ur passlock. my ignition cyclider did that before it locked up. 500 down the tubes.
Bad99Olds is offline   Reply With Quote
Old 03-25-2009, 04:50 PM   #17
99alerogirl
Female.
yeah i'll probably just build the spare up for boost i suppose. i know it's gonna be hella expensive, but that's the way i wanna go, so oh well. i need to read up on it!
Old 03-25-2009, 04:51 PM   #18
Bad99Olds
New and Improved
Bad99Olds's Avatar
reading is overrated.
Old 03-25-2009, 04:52 PM   #19
99alerogirl
Female.
yeah when you don't know how
Old 03-25-2009, 04:53 PM   #20
Bad99Olds
New and Improved
Bad99Olds's Avatar
hey, i learnd tew reed gewd. i spellz wel alsho.
