Old 04-02-2009, 12:55 PM   #1
Need HELP FAST!
i need the definite pushrod order for the front bank and the rear bank, and how to reinstall these properly without removing the LIM please!!
im going to push my goddamn car off a cliff!
Old 04-02-2009, 02:00 PM   #2
jackal2000
jackal2000's Avatar
ummm i dont think you can install them without removing the LIM.
Old 04-02-2009, 03:41 PM   #3
rustyballs_69
Its Beer Thirty
rustyballs_69's Avatar
Why not? Just pull the valve covers and pull the rockers off and they slide right out. Or I'm wrong because I haven't had my motor apart in a while.
Old 04-02-2009, 04:32 PM   #4
if you take the front valve cover off you should be able to get the rockers off and the pushrods out, however this might be tricky in the back. all i can say is remove the engine mount and try pushing the car backwards, as this may shift the entire engine forward in the engine bay and give you enough room in the back to easily get off the valve cover and the back rocker arms/rods
Old 04-02-2009, 09:17 PM   #5
done.... and i have no idea...... what the hell is wrong with this stupid engine
Old 04-02-2009, 10:17 PM   #6
I thought I gave you this info already?
Trust me its right, otherwise my car wouldnt be running...
You MUST rotate the engine over by hand to tighten the rockers down. You must tighten them with the pressure OFF the rocker arm.
If you assembled it wrong you may have bent a valve already. Even without running the engine.
