Old 04-03-2009, 01:11 PM   #1
rocker_boy55
rocker_boy55 is on a distinguished road
line out again!
ok so i've searched but i can nott find my answer's.....i'm trying to keep my head unit in as i didnt like the flow of an after market . i have a 2001 alero with the monsoon system. dose and one kno what colors the wires are (i need both left and right rears postive and negative(black strip i kno)) should be taping into. also what coulor is the power wire as i'l need that for my amp.
thanks again.
rocker_boy55 is offline   Reply With Quote
Old 04-03-2009, 01:18 PM   #2
You wont be tapping a wire for an amp.
Old 04-03-2009, 01:22 PM   #3
rocker_boy55
my mistake no i've ran my wires and every thing 4 gauge power 16 gauge for the line outs but i need a wire for the remote turn off an i'm going to be onest i dont want to play around with the fuses an other then that i just need to kno what coulor the rears are thanks
Old 04-03-2009, 04:09 PM   #4
ryanJ
ryanJ's Avatar
ryanJ is on a distinguished road
maybe its different for the monsoon, but cant you just look in the trunk where the 6x9s hang down.
ryanJ is offline   Reply With Quote
Old 04-03-2009, 04:10 PM   #5
rocker_boy55
ok so i found this chart on the alero with the monsoon option
http://3.bp.blogspot.com/_R5V9ulEuEi...io_diagram.JPG
how ever i taped my on/off switch to the orange wire hope thats right?
Old 04-03-2009, 04:15 PM   #6
ryanJ
ryanJ's Avatar
if you use the orange wire at the radio harness, the amp will not shut off. If youre talking about the orange ign harness wire youre good to go
Old 04-03-2009, 04:22 PM   #7
rocker_boy55
shit! ok so ign wire were do i find that? just by the key clyinder.. how do i get to it?
Old 04-03-2009, 04:27 PM   #8
ryanJ
ryanJ's Avatar
umm... you should be able to reach it once the radio is out. Just reach back there and pull the harness out some, cut back the tape to expose the harness. If youre not that experienced dealing with stuff like that, i suggest a fuse tap (much easier)
Old 04-03-2009, 04:46 PM   #9
rocker_boy55
ok so i can see the line you are talking about (i think lol) but thier is two orange wires how can i tell or do i just have to check with a meter on both of them.. i'm gessing ones in and one out but will it matter(yes i'm gessing) which one. an will i mess up the security system or n.e thing else?
if i were to tap into a fuse would to shut off but it self? (i want it to shut off by it self. lol)
