Old 04-04-2009, 12:09 PM   #1
tylerdelaney
tylerdelaney's Avatar
tylerdelaney is on a distinguished road
need help!!!!!!!!!!!
my car ran great last night and then it rained.now i lost my domelight,power trunk,power dlks and my car will start for only one or two seconds and then stall out.does anyone know what might of caused this and how i can fix it?thanks in advance.
tylerdelaney is offline   Reply With Quote
Old 04-04-2009, 12:28 PM   #2
sounds like you have the windshield leak that leaks onto the bcm..... go under the pass side of the floor in the car and see if it is damp if it is, you got problems
Old 04-04-2009, 12:28 PM   #3
Check the door seal on the passenger side, and the fusebox.
Old 04-04-2009, 01:12 PM   #4
tylerdelaney
is there any way i can take it out and fix it?
Old 04-04-2009, 01:36 PM   #5
Vinalero
Vinalero's Avatar
I would start wil hooking another battery in. Then look in all 3 fuses box for water.
Old 04-04-2009, 02:56 PM   #6
tylerdelaney
got it fixed i droped the bcm and water poured out so i took it apart and dried it.works perfect now.
Old 04-04-2009, 04:03 PM   #7
Vinalero
Vinalero's Avatar
Still, that means you've got a leak somewhere.
Old 04-04-2009, 04:10 PM   #8
5 bucks says it's the windsheild or pass door.
Old 04-04-2009, 08:39 PM   #9
I got 20 that its a midget with a hose...
Old 04-05-2009, 08:15 AM   #10
tylerdelaney
lmfao
