Old 04-14-2009, 06:51 PM   #1
1 Brake makes creaking/clicking noise?
My drivers front caliper... When I press on it it makes a creaking/clicking type noise. Like something not lubed up or is hanging up. The brakes seem to work well, but its f'ing annoying with the windows down.
It does it ALL the time. When is tart to press the pedal it starts to make noise.
As I said the brakes seem to work fine. THe cars not pulling to a side or anything.
Im thinking the Caliper is on its way out (dead?)???
I think i got replacement...
Old 04-14-2009, 06:59 PM   #2
jackal2000
jackal2000's Avatar
search 'creaking brakes'.
Old 04-14-2009, 07:04 PM   #3
CactusWill
Yeah, very common. Take the caliper apart, clean the moving parts and re-lube it all up good. Or just replace the caliper.
Old 04-14-2009, 07:25 PM   #4
z00m actually others with this problem.
lol
Well ok then.
Old 04-14-2009, 07:29 PM   #5
NickAlero2000
NickAlero2000 is on a distinguished road
Mine did it after I replaced my wheel bearing, its just the way the brakes wear and such, nothing serious.
EXTREME EDIT
Caliper siezed.
NickAlero2000 is offline   Reply With Quote
Old 05-29-2009, 08:33 PM   #6
dbailey
dbailey is an unknown quantity at this point
There is actually a TSB out on that problem. I did it to mine that were doing the exact same thing and it fixed it. There is an oil by a company named Kluber I think it is. The dealer sells it in these tiny little bottles. One for each caliper. You squirt it between the piston and boot and walla, no more noise. I thought I had posted the actual GM number for it a couple of years ago.
dbailey is offline   Reply With Quote
Old 05-29-2009, 09:42 PM   #7
mines been doing this... come to find out, my caliper pins on the passanger side were completely siezed in place. Just got parts, will have it fixed monday. (working solid until then)
Old 05-30-2009, 01:37 AM   #8
leoalero
leoalero's Avatar
leoalero is on a distinguished road
Send a message via MSN to leoalero
i did it yesterday on my 99',i replaced the two front calipers cause the caliper pistons were making creaking noise,now its perfect and no more noise,but for the one with this problem,i had to heat the bleeder valve to make turn cause it was welded together!!
some pictures
http://leoalero.monchar.com/
leoalero is offline   Reply With Quote
Old 05-30-2009, 07:59 AM   #9
Special oil! Snake oil?
Dang it. Oh well a brand new caliper was only $33. At least it wasnt to bad...
My caliper pins are all good. I bought a big bottle of caliper grease and I use it accordingly.
Old 05-30-2009, 08:03 AM   #10
jackal2000
jackal2000's Avatar
brsexton posted the TSB in my thread about this problem 4.5 years ago.
http://www.aleromod.com/forums/showt...reaking+brakes
Old 07-06-2009, 02:28 PM   #11
zlj1989
zlj1989's Avatar
zlj1989 is on a distinguished road
Send a message via AIM to zlj1989 Send a message via MSN to zlj1989
Yes I have noticed this on my '99 Alero. The problem is with the calipers. It's happened a few times but I just have the calipers re-lubed every time it happens. I go to Tireman Auto Center (if you've ever heard of them) and they actually do it for free.
zlj1989 is offline   Reply With Quote
Old 07-06-2009, 03:07 PM   #12
Ya I know where Andersons Tireman is
I got a new issue that Developed as I left ASS.
I think my tie rod end on the drivers side is shot.
It make s a weird creeking noise, not like the brakes. Only when I turn...
Argh stupid Alero.
Old 07-06-2009, 03:45 PM   #13
The dealership sells a lube thingy for it.
It's $6
Old 07-06-2009, 10:05 PM   #14
Psyfox
Psyfox's Avatar
Psyfox is on a distinguished road
Argh stupid Alero.
My mom's van had the same sound and it ended up being something with the suspension. Sorry I don't know the specifics on what was wrong, but I know it was something with the suspension. You might want to check that as well.
2001 Oldsmobile Alero GLS Coupe (black, 3.4L v6)- show car/college car project
Pictures can be viewed here: http://s10.photobucket.com/albums/a1...20Alero%20GLS/
Psyfox is offline   Reply With Quote
Old 07-08-2009, 02:39 PM   #15
NickAlero2000
Got an alignment today.
Apparently this creaking is a siezed caliper. Replacing later today.
For future reference, thought I should tell everyone.
