Old 05-16-2009, 01:47 PM   #1
nottooolds
nottooolds is on a distinguished road
brake problem
hey everyone. I just changes my front pads, rotors, left-front caliper, among other things. the car still doesnt have pedal pressure til i pump them, and i bled the system well, and there are no leaks.... any ideas? oh, and the left are still sticking on at times causing the car to pull to the left. any help would be great. is there a sequence you need to bleed the brakes in, is it something else?
nottooolds is offline   Reply With Quote
Old 05-16-2009, 03:40 PM   #2
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
either not enough fluid, or there is still air in the system. if you still need to bleed, put some fluid in the master cylinder, just above the line, and have someone help you with this (either pressing the pedal or watching the flow from the line) and pump it until there are NO breaks in the stream. You should only have to do this on the line(s) that was disconnected to replace the caliper.
And it sounds like you might have a ceased up caliper. This could be remedied with some precision smashes with a hammer.
Old 05-16-2009, 04:55 PM   #3
leoalero
leoalero's Avatar
leoalero is on a distinguished road
Send a message via MSN to leoalero
look at it,its a good way to be sure theres no more air in the system,I tried it and ill never bleed the other way!
http://www.youtube.com/watch?v=wdf--suwqw0
leoalero is offline   Reply With Quote
Old 05-16-2009, 07:14 PM   #4
that is awesome
Old 05-17-2009, 07:46 PM   #5
AlbinoMonkeyRat
Let's Play Army!
that video is effing awesome
Old 05-17-2009, 07:54 PM   #6
why the hell WOULDN'T you do your brakes that way? doy. its so common sense, it makes my face hurt.
to the old method...
Old 05-19-2009, 03:11 AM   #7
AlbinoMonkeyRat
Let's Play Army!
the old way does work....it just takes more time....and more effort because of this.
Old 05-20-2009, 12:43 PM   #8
nottooolds
turns out you do have to cross-bleed the system! i changed the front right, and had to bleed the back left! lol... so simple it hurts to think about it... car is on the road and running great. i'll post some pics this weekend hopefully...still need to wash, wax, and detail
