Old 05-22-2009, 06:57 PM   #1
Cashdollar2009
Cashdollar2009's Avatar
Bass Button
I want to put a "bass button" in my car and was wondering what exactly was the best way to go around doing this? Basically i'm just inserting a switch between the head unit and the amp n the turn on lead right? If not please correct me. Plus does anyone have any suggestions on which sitches to look into, a specific switch, and/or any install related pictures? Thanks in advance!
Under construction...
Old 05-22-2009, 07:14 PM   #2
so.. all you want to do is have a remote button to turn on your amp, which powers your subwoofers?
all you need is a switch with 12V power, running out to your REM input on your amp.
Old 05-22-2009, 07:50 PM   #3
Any 12V toggle switch will work.
Old 05-22-2009, 09:42 PM   #4
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
12v Rocker switches
Like they said!!
Cheap, easy to install and easy to hide.
I did this for my amps, just put the switches under the radio.
http://www.youtube.com/watch?v=hwHhjyGorlM
Just skip to 2:00 to see the switches.
PS The pioneer sub boxes are going to be remade into a new fiberglass box, so don't be to harsh. I just don't have the money to add any more to the radio.
Afugy is offline   Reply With Quote
Old 05-22-2009, 10:38 PM   #5
kinda gay, you will kill your battery if you forget it and leave it on, you should just get a head unit that you can shut the subs off through that.
Old 05-22-2009, 10:45 PM   #6
itsbmw
i just use the rocker switches from oznium. I have the wire coming from a switched power source(only comes on when the key is in the on/started position). then I ran it to the amp..
Old 05-22-2009, 10:49 PM   #7
This is true to an extent.
If the power is always hot at least. If your using the remote from the radio its impossible.
Now once you have more than 2-3 items on your remote wire you need to use a relay. Remotes only provide around 250-300 mA of power.
Old 05-23-2009, 02:56 AM   #8
I've done that before.. left it on that is.
Killed the battery, and somehow smoked the 40amp fuse in the amp's wire... :/
Old 05-23-2009, 11:16 AM   #9
^^^ hahahahahaha owned.
I switched my amps long ago and stopped. Just no need for it.
My only need is if I goto a drive in movie...
