So I rebuilt the car. Wouldnt start a week ago cause of passlock. That was fixed car ran and drove it around. Brought it home after running out of gas. Replaced fuel pump for the hell of it and radiator and condenser. Yesterday and tonight I've been trying to start it over and over again. The motor will start and then stall. I tried passlock like 20 times. Took a scan tool and turned of passlock and it ran for a minute so I shut it off to see if it would start without scan tool. It wouldn't. Tried starting again turning passlock off and no luck, It was like a fluke that it ran. So I looked into scan tool and it says passlock is registered and not the issue. So I am VERY confused!!! the only check engine light is p1671 witch is a mil control circuit. and I can't read my gauges due to the fact that they dont work. AND THAT IS NOTHING TO DO WITH THE ISSUE, and scan tool says security light is not on. And one thing thats confusing me is under bcm data there is Ignition output 0 INACTIVE, Ignition output 1 Active, and ignition output 2 Active. So whatever that is??? ANY HELP WOULD BE AWESOME!!
