So i'm setting up the build sheet for the motor I'm going to build. Heres what i have so far
:block bore .060
with oversized forged pistons 10.5:1
Double roller timing chain
wot-tech roller lifters with ls spring
wot-tech street strip performance heads
competition series manifold set w/ 65mm tb
question is what cam would be best? I'm running n/a
I'd ask Ben to run a simulation for you to see what would work best for your goals/needs. The cost of the camshaft selection service is credited to you when you buy a cam.
