Old 09-20-2009, 05:29 PM   #1
2blessedalero
2blessedalero is an unknown quantity at this point
Question Brake Caliper Problem (Emergency)
Today I tried to change my brake pads but when I tried to use a c-clamp to push the piston back, it won't go anywhere. After riding for a long time with no brake pads I think I over extended my piston in my caliper. What do I need to do?
2blessedalero is offline   Reply With Quote
Old 09-20-2009, 05:36 PM   #2
did you take the cap off the brake fluid reservoir
[ion] C2 is online now   Reply With Quote
Old 09-20-2009, 05:41 PM   #3
2blessedalero
Yes I took it off. What else could it be?
Old 09-20-2009, 05:43 PM   #4
hold on, you drove with NO BRAKE PADS!?!?
Group Faceplam!!!!!
anyway, WRENCH that C Clamp down
Old 09-20-2009, 05:51 PM   #5
he means really really worn down pads...
Old 09-20-2009, 06:05 PM   #6
bkathsalero
bkathsalero's Avatar
bkathsalero is on a distinguished road
Send a message via MSN to bkathsalero
try and crack the bleeder it will make it alot easier
bkathsalero is offline   Reply With Quote
Old 09-20-2009, 06:13 PM   #7
freeze12
Probably need new calipers.
...Dan...
Old 09-20-2009, 06:38 PM   #8
-Alero-
-Alero-'s Avatar
also try releasing your brak booster line, it also holds alot of pressure in the master cylinder.
and yes old calipers put up a fight. i use a wood block and a metal c clamp and go really slow.
but if all else fails you can rebleed and remove the caliper and exchange it for a new one at autozone for 30-40$ they are cheap because....they are cheap
AUTOBOT
Old 09-20-2009, 07:13 PM   #9
A57
A57's Avatar
A57 is on a distinguished road
Send a message via Yahoo to A57
^^^^ there you go its alot easyer to replace than fight a bad caliper..make sure to grease the bolt pins to...
A57 is offline   Reply With Quote
Old 09-20-2009, 07:27 PM   #10
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
And when you get new calipers get a Disc brake pad spreader, its WAY better then using a c-clamp. Its only 8$ and can save you from effing up caliper pistons, even though you piston was most likely effed before you used the c-clamp.
http://www.autozone.com/autozone/cat...uestid=1034254
Afugy is offline   Reply With Quote
Old 09-20-2009, 07:54 PM   #11
2blessedalero
I took off the brake line and used a c-clamp and finally got it back on! Thank you Jesus! But now when I press the pedal, I have to go all the way to the floor. I think I have air in the line. What do I do?
Old 09-20-2009, 07:58 PM   #12
you have to press the pedal up and down a bit before you drive it for the first time and then it'll be normal
Old 09-20-2009, 07:59 PM   #13
Afugy
I poop alot
Afugy's Avatar
http://www.youtube.com/watch?v=Hf1iPbeg778
If you did remove the brake line, you should bleed the brakes from the caliper you removed the brake line from, if you still are not happy bleed all the brakes.
Warning: if you had to use to much pressure using the c-clamp your piston and or piston wall of the caliper are screwed and is likely to jam on you again. So it would still be a good idea to change the caliper.
