Old 09-30-2009, 05:47 PM   #1
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
knock sound with steering
everytime I steer for more than a 90 degree turn on the steering wheel, I hear a knock when I come back to center. This happens in both directions. Any ideas? Any "for sure" diagnosis?
I just replaced the rack and pinion about 2 years ago, and I think it is still under warranty from the shop that replaced it.
Thanks.
Old 09-30-2009, 05:53 PM   #2
mine does it too... clunks in the floorboards, ill wait til it breaks
Old 09-30-2009, 06:29 PM   #3
CactusWill
Most likely a suspension component. Which one I dunno. You'd have to get the car in the air and feel the joints for play.
Old 09-30-2009, 06:45 PM   #4
Caboose73
Probably a bad cv joint
Old 09-30-2009, 07:21 PM   #5
IRONDOG442
IRONDOG442's Avatar
IRONDOG442 is an unknown quantity at this point
Send a message via AIM to IRONDOG442
intermediate shaft
/end thread!
IRONDOG442 is offline   Reply With Quote
Old 09-30-2009, 08:11 PM   #6
AlbinoMonkeyRat
Let's Play Army!
^ okay. how much does this repair usually cost?
Old 09-30-2009, 08:58 PM   #7
as i would also like to know
Old 09-30-2009, 10:19 PM   #8
check your front coil springs to see if one is snapped. that makes it clunk like that when you turn, it happened to me.
Old 10-01-2009, 05:21 PM   #9
AlbinoMonkeyRat
Let's Play Army!
makes sense.......
Old 10-01-2009, 05:25 PM   #10
On the same note, check to make sure your upper bearing isn't seized up. If that happens it does the same thing... have someone steer the car and watch the springs, if the wheels turn, but not the spring, then all of a sudden it pops to catch up with the wheels, then its the bearing.
Otherwise if it sounds more inside the car, check the column.. isn't there a little universal joint in it? that may be making noise.
Wouldn't be a CV.. those click and make noises when its turned and moving (if it's the outer joint)
Old 10-01-2009, 05:27 PM   #11
^very true, thats what i first figured it was when mine did this. but i pulled the assembly out and was surprised as hell haha
Old 10-01-2009, 05:29 PM   #12
eh, mine's in the floorboards, i know my SM's are effed, should hea rthem on a slow turn...............oh god bad
Old 10-01-2009, 08:27 PM   #13
AlbinoMonkeyRat
Let's Play Army!
mine does sound like it's a spring thing, now that I've dealt with it a bit more. I thought maybe it was unseated or something, but they've been on forever...so being seized up makes more sense.
Old 10-02-2009, 12:09 AM   #14
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
Thanks.
strut mounts
Old 10-02-2009, 08:06 AM   #15
IRONDOG442
IRONDOG442's Avatar
$117 with tax. Strut mounts are also a very good possibilty.
Old 10-02-2009, 11:00 AM   #16
AGT
AGT's Avatar
I'm thinking CV axle. I replaced 2 in my alero. If you drive it hard its a weak point
Have a good day
Old 10-02-2009, 01:41 PM   #17
That only makes noise when you're moving, and it'd be a clicking or s it progresses a clunking.
Old 01-06-2010, 11:01 AM   #18
AlbinoMonkeyRat
Let's Play Army!
strut mounts were worn, but not broken. I'll put that off for some other time. But what was causing the noise (somehow) was the sway bar/link was broken. So I got a new OEM sway bar (I wish I knew this was the problem before the group buy came around) and I got a new sway bar and link kits and bushings.
