Old 10-27-2009, 10:53 AM   #1
need help with new box
so anyone i broke the seal on my last box because i guess i used 3/4" thick MDF and kinda rushed making it. what im looking to do this time is just use one of my HCCA 12.2 and hook both my 2400 amps up to it in a bigger box made with 1" MDF this time, and just sell off the second sub.
the current box i have in there right now is 17"x42"x7.5" and that is as big as the box can possibly go, but im switching from two subs to one and i cant seem to find the proper space i need for one of these subs to hit properly. they are orion HCCA 12.2 (the new 2009 models)
anyway the 2 fixed variables on the box are the height and depth, but i can change the width from 42" to anything smaller, i just need to find out the proper CU i need and change it.
Old 10-27-2009, 12:12 PM   #2
get or make a bandpass box they are great and make an amp tray for the tow amps.
Old 10-27-2009, 02:30 PM   #3
Dud you got 3 cubic feet... Thats considering the outside dimensions...
These are 12's or 15's?
You MIGHT have enough room for 1 12 and get decent with it.
To small for a 15".
Old 10-27-2009, 05:32 PM   #4
Cashdollar2009
Cashdollar2009's Avatar
C'mon man...
Under construction...
Old 10-27-2009, 06:05 PM   #5
they are 12" dual 2 ohm
when i upgraded i didnt realize that these new models require so much space which is why i am changing my setup to only 1 sub on my 2 amps with a bigger box.
Old 10-27-2009, 07:05 PM   #6
Isnt there room available where the sub sticks up?
Got a T/S spec sheet for them? link?
Old 10-28-2009, 03:49 PM   #7
Fi-Alero
Fi-Alero's Avatar
Fi-Alero is on a distinguished road
Wow, bad idea for that sub in our vehicles. There's alot more to a bandpass box than just throwing something together...
The HCAA 12.2 is very inefficient. I'd give it around 3cubes net to try to squeeze a little more efficiency out of it. Tune a bit higher on paper also due to our trunks like to tune a lot lower in vehicle.
Fi-Alero is offline   Reply With Quote
Old 10-28-2009, 03:53 PM   #8
i am getting a custom box made for my subs. get a custom one.
Old 10-28-2009, 04:17 PM   #9
Fi-Alero
Fi-Alero's Avatar
Old 10-28-2009, 04:19 PM   #10
Originally Posted by Fi-Alero View Post
what you do not like the idea of a custom box.
Old 10-28-2009, 06:44 PM   #11
You think ANY of this discussion pertains to a prefrabicated box?
Its all custom...
I build customs..
Fi Builds also.
If you got to maintain the box and want it unique:
I would make it as large as possible. Invert the sub as you have been and use a 6" Aero port externally also.
Old 10-28-2009, 11:03 PM   #12
A57
A57's Avatar
A57 is on a distinguished road
Send a message via Yahoo to A57
WOW thats a big ass box... shit my 3 12's dont have that much space...but they are only meant for .85 cube each... but i rounded up to 1...
good luck, pm if you need some help, oh 3/4 is the best unless you like picking up 250 lbs of wood...
BUILDING A V8 ALERO 2DR
A57 is offline   Reply With Quote
Old 10-29-2009, 10:06 AM   #13
its not that big of a box...i had one twice the size before i had all my air ride shit in the trunk
Old 10-29-2009, 11:06 AM   #14
I will stick with my earlier statement.
Make the box as large as you can. Invert mount the sub and the 6" Aero port tuned to whatever you want it to.
Old 10-29-2009, 06:48 PM   #15
Cashdollar2009
What's the benefit of keeping the sub inverted? Just curious.
Old 10-29-2009, 07:13 PM   #16
Doesnt take away an airspace from the box. Same deal with the port...
Not like he has much room to work with anyhow.
Old 10-30-2009, 09:52 AM   #17
Ian 2000GL LA1
Ian 2000GL LA1's Avatar
Ian 2000GL LA1 is on a distinguished road
Send a message via AIM to Ian 2000GL LA1
what fQ would u like it tuned to? i prefer the 36hz range, and i think that generally excepted, Ill design you a box latert tonight and send u the dimensions i think u can pull more than 3 cubes the 18" i have in my trunk has more than a 3 cube box w/1" MDF you might want to concider doubling 3/4" MDF.
Ian 2000GL LA1 is offline   Reply With Quote
Old 10-30-2009, 10:36 AM   #18
Fi-Alero
Fi-Alero's Avatar
Just throwing out a random tuning means nothing...
Grim has alot less space than you lol. He does have all this air ride stuff...
I agree with Ryan on this one. Make the box as big as you can up to 3 cubes, and make everything external. Grim kind of has the wrong sub for his situation lol.
