Old 10-31-2009, 10:21 AM   #1
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
Turn signal problems
About one in the morning my turn signals quit working. Fuse C on the drivers side panel is fine. Everyonce in a while last night they would work for a few seconds and quit alltogether.
Old 10-31-2009, 10:22 AM   #2
worknprog.99
worknprog.99's Avatar
bad ground
Old 10-31-2009, 10:25 AM   #3
hazard button
Old 10-31-2009, 10:28 AM   #4
MattismodderX
MattismodderX's Avatar
MattismodderX is on a distinguished road
Send a message via AIM to MattismodderX
search button works wonders for this
Officially addicted to bass.
MattismodderX is offline   Reply With Quote
Old 10-31-2009, 10:31 AM   #5
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
i saw the hazard issue, mines different and the haszzard works fine
wheres the turnsignal ground? thats easy to check
Old 10-31-2009, 10:35 AM   #6
you haven't noticed if you hit your hazard button a couple times the turn signals will work?
Old 10-31-2009, 10:47 AM   #7
hazard can work fine, its the solder in the button, YOU DO KNOW that the hazard button is also the turnsignal thing? you fail
Old 10-31-2009, 10:51 AM   #8
AtomicX
AtomicX's Avatar
Does your horn work?
If not then its the ground to the relay under the hood.
Old 10-31-2009, 11:14 AM   #9
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
ok, ill check the horn, yall r saying its not the #22 relay? or the turn signal switch, and where do i get the new hazzard button
Old 10-31-2009, 11:16 AM   #10
Hazard button can be bought anywhere that sells auto parts
Old 10-31-2009, 01:31 PM   #11
colonel6632
colonel6632's Avatar
did you try cleaning the turn signal switch
Old 10-31-2009, 01:41 PM   #12
Hazard button is like $20 online at GMpartsdirect. Takes maybe 15-30 minutes to replace, and BOOM! Your done.
Old 10-31-2009, 01:57 PM   #13
Paul.C
Paul.C is on a distinguished road
i have the same prob if u press the hazard button half way a good indication is that your button will buzz i dunno why but in a pinch hit the top of your dash it will work or press the button in half way
Paul.C is offline   Reply With Quote
Old 10-31-2009, 04:58 PM   #14
kingjames64
kingjames64's Avatar
kingjames64 is on a distinguished road
dude listen to nate and matt its the hazard switch I promise
kingjames64 is offline   Reply With Quote
Old 10-31-2009, 05:26 PM   #15
01OldsAleroGt
01OldsAleroGt's Avatar
01OldsAleroGt is on a distinguished road
Send a message via AIM to 01OldsAleroGt Send a message via MSN to 01OldsAleroGt Send a message via Yahoo to 01OldsAleroGt
yea.. i have the same issue with it working on and off... gotta pull out my hazard and check it.. the signals will work when i love tap the dash when they stop working. But yea.. listen to em
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
01OldsAleroGt is offline   Reply With Quote
Old 10-31-2009, 10:12 PM   #16
undersc0re
undersc0re is on a distinguished road
Those hazard buttons are defective, they had an issue with cold solder joints, and the little tiny resistors or whatever in there come loose(solder joint cracks barely noticable) which is why when ya push on the switch sometimes your lucky enough to make a connection to get your signals to work, if your lucky enough to notice which one and have very good soldering skills maybe you can fix it and put it back in. The signals circuit goes right through that hazard switches circuit board so it affects the signals, sometimes they work and sometimes they click like crazy etc....It was a recall/safety issue around 2001. The dealer should do it for ya at no cost.
undersc0re is offline   Reply With Quote
Old 02-15-2013, 03:17 PM   #17
Mine just started acting up last night for the first time.
Used the SEARCH BUTTON and it works great. I didn't even have to start a new thread.
$18.58 on eBay, brand new, shipped right to my door. ACDelco part number 10359040
Old 02-15-2013, 06:03 PM   #18
You get a GOLD star Ken.
Old 02-15-2013, 06:38 PM   #19
number53alero
number53alero is on a distinguished road
Mine started doing this too but is resolved by a simple light nudge up with a finger to the hazard button. Once it gets worse I'll replace the hazard button. Thanks for the info!
2004 Final 500 Alero #53
http://www.cardomain.com/ride/718701
1990 Cutlass Ciera Lowrider
http://www.cardomain.com/ride/212170
2002 Aurora 4.0L V8
http://www.cardomain.com/ride/3045018
number53alero is offline   Reply With Quote
Old 02-15-2013, 10:00 PM   #20
like was probably said you may have to pull your multifunction switch and clean it...Mine worked fine for about a week and then it started acting up again...cleaned multifunction switch and all is good
