Old 10-31-2009, 08:00 PM   #1
dmcb2120
dmcb2120's Avatar
dmcb2120 is on a distinguished road
my car wont start.
I change the head gaskets now car wont start . It turns over like its stuttering then make a noise like a some lil poof. But when i remove the fuel pump relay it turns over fine . I need help please someone asap I have to be to work in the morning. It has spark i did the screwdriver the body test . There is plenty of fuel coming out the pressure relief valve 3133101696 Dmcb2120@gmail.com
Cleared corners- painted bezels black - tinted taillights - already had tinted windows - Pioneer head unit - 2 12" type R's - 2 SPL crm 1200 watt amps.
dmcb2120 is offline   Reply With Quote
Old 10-31-2009, 09:17 PM   #2
comanche
comanche is an unknown quantity at this point
So it turns over perfectly if the fuel pump relay is removed?
Weird.
Maybe you wired up the injectors incorrectly? I suppose it's possible to switch the harness around.
Or maybe switched the fuel in/out lines around?
Sounds fuel related.....
comanche is offline   Reply With Quote
Old 10-31-2009, 09:38 PM   #3
compression test, or video plz
Old 10-31-2009, 10:58 PM   #4
dmcb2120
dmcb2120's Avatar
stupid me !!!!!!!! On my car the intake is numbered (back) 2.4.6 (front) 1.3.5
So I wired the wires up all wrong. It was suppose to be (back) 1.3.5. (front) 2.4.6 .
I think my intake was made on a day after someones vacation. Is anyone elses like that ?
