Old 11-12-2009, 12:43 AM   #1
white04alero
white04alero's Avatar
white04alero has a little shameless behaviour in the past
wtf
hey, stereo is crapping out it seems like. idk what the deal is.
all this started yesterday. i start my car, and no radio. nothing. hitting all sorts of buttons, etc, checked fuses, everything seems to be good. when my car warms up, sometimes it comes on, sometimes it doesnt.
my stereo is a Pioneer DEH-P4900iB, with a chimes module thing, made by metra i think.
any ideas? driving in silence makes me insane.
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
white04alero is offline   Reply With Quote
Old 11-12-2009, 12:44 AM   #2
white04alero
http://www.crutchfield.com/p_130DEHP...si=0&tp=56 84
specs, etc. just in case
Old 11-12-2009, 09:22 AM   #3
a4d2a0m
a4d2a0m's Avatar
a4d2a0m is on a distinguished road
I would pull it out and see if it makes a diff... it is pretty tight for aftermarket units. If you installed it (or whoever) and didnt cut anything out inside the dash the frame might be wedged up against your harness causing a poor connection depending where the plug is.
I have no experience with the chime module.. never used one, does the power or acc run through it??
a4d2a0m is offline   Reply With Quote
Old 11-12-2009, 11:16 AM   #4
MattismodderX
MattismodderX's Avatar
MattismodderX is on a distinguished road
Send a message via AIM to MattismodderX
man i wish our cars had more room for the head unit. i have a pioneer AVH-5700DVD and jesus christ it barely fits. it pops the plastic frame out just about every time im in the car.
Officially addicted to bass.
MattismodderX is offline   Reply With Quote
Old 11-12-2009, 01:00 PM   #5
a4d2a0m
a4d2a0m's Avatar
You need to take a dremel or rotary tool(worked best for the small spot.) and cut the hole in the back frame larger to allow the unit to go in without obstuction.
Old 11-12-2009, 01:33 PM   #6
MattismodderX
hmmm. i might just do that today when i replace the rotors. it would make life much easier to work in there
Old 11-12-2009, 02:06 PM   #7
pull it out, the wires are probably loose or messed up from being pushed so damn tight against that unneeded piece behind the stereo.
