11-23-2009, 05:03 PM
2.4 LD9 swap
I'm faced with a decision... do the LIMG fix again, swap in an LD9, or get rid of the car.
Is the LD9 a direct drop-in for the 3400?
2002 Alero 3400 4 door
11-23-2009, 05:10 PM
Owner
it will drop in. it uses most of the same mounts if not all. the only thing is you will need the 4t40 tranny (duh) and the PCM and BCM and wiring harness.
Beware of the BackStabber
11-23-2009, 05:45 PM
its a fairly simple swap, just would take a lil bit more money b/c of also needing a different tranny and wiring harness. the bcm and pcm could be found used for cheap. Imo, if i was gonna go thru all the hassle of swapping the engine and tranny, i'd put in a 5 speed.
11-23-2009, 06:23 PM
i have an extra pcm and bcm i would sell you for cheap its from a 2000 ld9
11-23-2009, 07:16 PM
w00t!
11-23-2009, 07:30 PM
do the LIMG, just do that, MUCH easier
11-23-2009, 07:56 PM
The lower intake manifold gasket would be easier. Hell Im gonna rebuild a 3400 soon. I'll post pics.
11-23-2009, 08:31 PM
please do
11-23-2009, 09:36 PM
Did you replace with metal gaskets?
2002 Oldsmobile Alero GL 1990 Nissan 300zx n/a 1991 Nissan 300zx TT
11-23-2009, 10:40 PM
Originally Posted by Nate's Alero
please do
I will but it will be on a GA/GT. Front/lower head gasket needs replacing. Not mine, its a friends so once he gets the car over to a suitable place I will begin working on it.
He wanted me to work on it in a apartment parking lot
Not how I work
11-24-2009, 08:29 AM
Good to know, thanks!
True, very true. I was just throwing an idea out.
Yep, the kit from wot-tech. It ran fine for a few months... now not so much.
11-24-2009, 10:46 AM
Owner
i agree with the 5-spd idea.
