Old 12-10-2009, 10:19 AM   #1
MattismodderX
MattismodderX's Avatar
MattismodderX is on a distinguished road
Send a message via AIM to MattismodderX
American Bass Install- custom 5.25 brackets
(thread moved. id like some advice!)
Ok so it only took from 4:30pm to 10pm but i got the front two american bass 4x6s in the font doors and rerouted them to the headunit. after i did that it sounded great but the 6x9s in the back sounded like dirt in comparison. the 6x9s only played mids and hardly any lows. the stock amp wouldnt let me have the tweeter on it hooked up with the mids hooked up. so i rerouted the wiring to the headunit for them and now the highs are crispy fresh! didnt get to make a baffle for the 6x9 adapter to fit the 5.25s.. it was too late. below are pictures of the install, the 5.25 baffle will be done tomorrow. any ideas that are out of the ordinary? i was going to mount some kind of wood and cut out the hole for the middle of the 6x9 adapter bracket and have the speaker in the middle with the speaker cover. any creative ideas on a different kind of baffle is welcome. (not fiberglass)
also something completely unrelated... so after installed the speakers i go to leave.. crank up the bass and it sounded waaay different. before it was clean as hell. every bass hit between 24-35hz was perfect deep. now it seems like its not quite as clean/perfect sq but quite a bit louder. it vibrates hella ridiculous hard now and i think it HAS to be hitting at least 140. the song i used for the db drag that has the highest spl on a constant sounds way louder. it sounds so much better on just about every song i have. even the low ones. better response too on every tone it playes. personally i listen to my car full blast at least 2 hours+ a day since september. i remember thinking just yesterday how i think either im getting deafer or the sub is getting quieter. now i can notice a major different. i didnt touch any of the sub wiring/amp settings/headunit setting, nothing.. it just hits crazy hard now. any ideas as to wtf happend? im really excited about this. its like a miracle or something. id there has to be a possibility. all i did was rewire all the speakers to the stock head unit. it still has the remote wire to it connected to the harness tho
i thought the packaging was pretty damn good for the price.
soo beautiful
the old 4x6 compared to the new one. time to cornstarch/water experiment with them! the pictures are pretty dark because the garage i was working in had one 60w bulb on the other side ceiling and i had a table light with an extension cord inside my car. it actually turned out working better then any other light source. even daytime.
the wires were a nightmare for the headunit- but i ended up brute forcing and a vice grip to take out the piece of plastic that wouldnt let it go in all the way. all i had was electrical tape to connect everything unfortunately
photo of the speaker installed in the door. ill add some silicone tomorrow to seal up all the gaps due to the speaker not being big enough lol
the headunit finally fits perfectly inside without being slanted and pushed out to much. overall the speakers in the front are much much cleaner compared to the old ones. totally worth every penny. the highs in the back are on as well making it sound better all around.
Officially addicted to bass.
MattismodderX is offline   Reply With Quote
Old 12-10-2009, 10:26 AM   #2
Looks good
Old 12-10-2009, 12:12 PM   #3
MattismodderX
thanks. ill post the rest tomorrow when my check cashes. ideas are welcome
Old 12-10-2009, 05:00 PM   #4
Fi-Alero
Fi-Alero's Avatar
Fi-Alero is on a distinguished road
Everything looks good except for the electrical tape connections. I can not begin to count how many radio installs I've had to fix because of that. I would recommend going back and at least use butt-connectors to connect the wires as soon as possible.
Painted, boosted, bagged, too many mods to list..
Two DigitalDesigns 2510s, two RD1750.1s, one loud Alero
Fi-Alero is offline   Reply With Quote
Old 12-10-2009, 05:07 PM   #5
MattismodderX
i plan on it when its warmer out. ill hold the winter for sure. had them on my car since i first bought it. i just make sure to tape it real good/clean so it wont ever come apart unless its physically disturbed.
i can tell no one read the 2nd paragraph about the sub. or if they did just dont know me well enough to care but id love to hear how its possible for it to just completely change the sound w.o touching/disconnecting any of the sub wiring. i HAS to be hitting at least 140 now.
so today i decided to snap a couple shots of the car. i added window tint all around to add to the murderocity of the alero. forget oldsmobile. murdermobile! the rims look amazing shiny and tire-wett'd but the salt covered that up pretty damn quick
cleaned up the box install a hell of a lot since last time.. sanded down the hole to fit the rubber surround and flipped the box/sealed the holes on the bottom. the jumper cables are there because my car has died a few times in the past week and its faster then AAA. had the acc on too long.
Old 12-13-2009, 06:15 PM   #6
tsmitty025
tsmitty025's Avatar
tsmitty025 is on a distinguished road
I have used electrical tape connections in all 3 of my vehicles throughout 7 years and have never had a problem with it. no worries.
2001 Oldsmobile Alero GLS
tsmitty025 is offline   Reply With Quote
Old 12-14-2009, 12:23 PM   #7
Fi-Alero
Fi-Alero's Avatar
That just means you have good luck lol.
As I said earlier, I cannot begin to count how many vehicles I have had to repair the radio install on because of electrical tape. Not only can it result in a loose connection, but it also can result in an unseen bad connection.
Old 12-10-2009, 05:55 PM   #8
Did you unhook the radio when wiring up the speaker? Undo the battery?
If so you may have changed your crossovers or sub output gain.
The loud feature may be enabled.
Your previous eq settings may have been whipped.
Most radio's fully reset when unplugged.
Old 12-10-2009, 06:02 PM   #9
MattismodderX
it does reset every time it loses power. i set all the settings in every last corner of the headunit. the loud feature is always off. dont even know why its there. with the sub on 0 its quieter then before but when i put the gain on the amp where its supposed to and add +3 to 4 on the subwoofer setting menu it beats STUPID hard. waaaay harder then it ever has. went from dayum to
Old 12-11-2009, 01:24 PM   #10
Fi-Alero
Fi-Alero's Avatar
You have a setting changed somewhere.
Which most likely means it is receiving a stupid distorted signal
Distortion can create the illusion to the ears that you bass is louder, but in reality, it is just killing your subs.
Old 12-11-2009, 01:39 PM   #11
MattismodderX
ive been kind of expecting it.. i found a rip in the spider the other month and havnt just been beating it until it doesnt beat any longer.. then i can just get a recone. what could cause this distortion? i really think it sounds better on a lotta songs. especially the high SPL songs
UPDATE: bought a piece of birch wood 2"x2" to cut the baffles out and some silicone to seal it in. will hopefully get it done tonight, if not almost all the way. pictures for days as usual
Old 12-11-2009, 02:35 PM   #12
Seal the fronts also!
Old 12-12-2009, 01:36 AM   #13
MattismodderX
does it make them louder? they seem a quite a bit quieter then the stocks at more rms
Old 12-12-2009, 07:47 AM   #14
so if i get that set of massives, i should make a box for them, on the back of the door?
or are you talking about the backseats?
Old 12-12-2009, 12:37 PM   #15
Fi-Alero
Fi-Alero's Avatar
The only way to go in the front is 6 1/2s with custom fiberglass pods
Old 12-12-2009, 02:02 PM   #16
i'm well aware of that. I'm planning on fiberglassing my doors, since my current pods are fugly-tastic.
i'm just wondering if i should seal the back, of it?
Old 12-12-2009, 02:53 PM   #17
Fi-Alero
Fi-Alero's Avatar
If you wanted a little better mid-bass response out of your door speakers, you could sound deaden the door to seal it off a bit. It should help alot.
Old 12-12-2009, 03:16 PM   #18
The whole concept is to keep the front wave from meeting the rear wave.
Take it how ya want.
Old 12-12-2009, 03:17 PM   #19
MattismodderX
UPDATE: the guy whos tools i was gonna use had them all out on a job 40 miles away (residing a house) so i couldnt do it yesterday. will be completed today tho! eff yeah!
Old 12-13-2009, 02:24 AM   #20
MattismodderX
Ok so the baffles are created! the speakers fit great but gotta wait for the adhesive to dry. gonna paint them around 10am tomorrow then install the speakers in them that night. will have photos of the completed baffles then!
LOL this is back side of the first one i made.. looked like DIRT. ended up tossin it
the second one. much more pretty and symmetrical
mm yess fits quite nicely
pre-glued
after-glued. will be sanded and painted tomorrow!
the backside. adhesive out the ass!
painting 10am sharp followed by the install. rest of the pics up sunday night!
