Old 01-04-2010, 04:15 PM   #1
Xtrm
Xtrm's Avatar
Xtrm is on a distinguished road
Send a message via MSN to Xtrm
Whats wrong now ??????????? :(
So im driving along today and the parking bake light comes on. Im like wtf. So i check the P Brake and it is not engaged. I turn off the car, turn it back on and all is good. 10mins later back on. I checked my brake fluid and its good. What can this problem be????
2003 Alero GLS 3.4L
Xtrm is offline   Reply With Quote
Old 01-04-2010, 04:24 PM   #2
bentiac
bentiac's Avatar
bentiac is on a distinguished road
Does the ABS light come on as well? I think your pads are gone!
GS - 01 Alero Coupe - MT, CG-lock,Front/rear strut tower brace,WAI,Fidanza Short throw Shifter and custom short throw clutch, AGX adjustable struts and mounts, Dropzone Springs, speedbuilt front sway bar, Toyo R888.
CS - 06 RX8 - Special Edition Shinka, 285 Hoosier A6.
bentiac is offline   Reply With Quote
Old 01-04-2010, 04:58 PM   #3
colonel6632
colonel6632's Avatar
my brake light used to come on. but so were my abs, trac off, and svs light for a wheel bearing. replaced said wheel bearing, light hasn't come on since
Old 01-04-2010, 05:28 PM   #4
hmmm. maybe metering valve or pressure differential valve...
does the car stop the same?
Old 01-05-2010, 06:40 AM   #5
Xtrm
Xtrm's Avatar
ya the car stops the same. i know i need to replace the bearings, i just have not gotten around to it becasue of the holidays. but today i have to drive back home 6 hrs i just hope its safe to do so.
2003 Alero GLS 3.4L
Old 01-05-2010, 06:50 AM   #6
well, if it stops the same....take it SLOW... and keep checking your brakes...
Old 01-05-2010, 12:02 PM   #7
whiterider00
whiterider00's Avatar
double check the fluid. mine did that for about a week, and it was the brake fluid. it was just barely below the full line so when i took sharp turns, or when it was really cold it was enough to set off the sensor.
Old 01-05-2010, 02:20 PM   #8
Vinalero
Vinalero's Avatar
Some ppl had to change the actual sensor in the brake fluid tank. Maybe it is shot.
Old 01-05-2010, 03:59 PM   #9
Xtrm
Xtrm's Avatar
Alright. Thanks for all the input.
2003 Alero GLS 3.4L
Old 01-08-2010, 02:28 PM   #10
colonel6632
like i said, mine was just coming on while driving around, new brake shoes, full of fluid. i let my wheel bearing go for about 3 months,and it just started coming on in the last week or two. When i changed the bearing, it hasn't come on since.
Old 01-09-2010, 01:36 AM   #11
sounds like you need to bleed the brakes
Old 03-23-2010, 06:55 PM   #12
Xtrm
Xtrm's Avatar
Sorry for bringing this thread back to life but my issue had gone away, but has now returned. New pads and rotors front and back, new bearings. light comes on almost instantly when i start the car.
2003 Alero GLS 3.4L
Old 03-23-2010, 06:56 PM   #13
Xtrm
Xtrm's Avatar
How do I bleed the brakes? I have never done this before.
2003 Alero GLS 3.4L
Old 03-23-2010, 10:56 PM   #14
El Pablo
03 Subaru WRX
El Pablo's Avatar
El Pablo is an unknown quantity at this point
Send a message via AIM to El Pablo Send a message via Yahoo to El Pablo
One time my brake light came on. I needed a little bit of brake fluid in my master cylinder. I topped it off and I was good to go. Bleeding the brakes isn't a bad idea however, I chose not to do that lol.
El Pablo is offline   Reply With Quote
