Old 01-06-2010, 11:54 PM   #1
Ian 2000GL LA1
Ian 2000GL LA1's Avatar
Ian 2000GL LA1 is on a distinguished road
Send a message via AIM to Ian 2000GL LA1
21" sub in my Trunk
Thats right, no Typo
i said it couldn't be done
im shooting for a massive box, with a forward firing square port. already got the juice, just need an amp, that'll be next week. probably going for an AP3500.1 only 399.99.
EDIT:
Just measured, biggest box i can fit is through the cab, door off , might have to take seats and consol out to get it into car is 34Wx15Hx 30D = 7.23cubes with a wood displacment of .75.
Ian 2000GL LA1 is offline   Reply With Quote
Old 01-07-2010, 12:22 AM   #2
good luck getting a 21"x16" in the trunk with a 6cube box
Old 01-07-2010, 12:22 AM   #3
MattismodderX
MattismodderX's Avatar
MattismodderX is on a distinguished road
Send a message via AIM to MattismodderX
replace backseats?
Officially addicted to bass.
MattismodderX is offline   Reply With Quote
Old 01-07-2010, 12:35 AM   #4
Ian 2000GL LA1
box in first, cutting box set sub in fix box from inside and outside, done. SPL isn't pretty.
Originally Posted by MattismodderX View Post
replace backseats?
done it, didn't have the output i wanted and no passengers or place for my junk, it sucked. http://www.myspace.com/ianp35 check my pics.
Old 01-07-2010, 12:38 AM   #5
Ian 2000GL LA1
i was wrong mounting depth is only 11 7/8's this is going to be cake! if i bring the height down to 14" i can slide sub and box in at once.
Old 01-07-2010, 01:19 AM   #6
Hmmm, 5 x 5 port needs only about 6-8 inch depth for 30-34 hz tuning. Guess it can be done, should be interesting. What tuning are you going for?
Old 01-07-2010, 06:18 AM   #7
5"x5" port is WAY to small...
21" sub?
What is it?
Audiobahn? Clarion wok sub? Jackhammer? (22").
Only other 21" sub I can think of is an old Autotek sub.
Old 01-07-2010, 08:42 AM   #8
If he goes larger than that, though, the port length will have to be deeper, and it will cut into his 6 ft enclosure volume.
Old 01-07-2010, 09:25 AM   #9
worknprog.99
worknprog.99's Avatar
is there even songs that that wil be functional? i mean bass is cool if we can here it but if only the dogs are ahowlen then it is kinda useless eh? lol
Old 01-07-2010, 09:47 AM   #10
Bruscomusco
Bruscomusco's Avatar
Bruscomusco is on a distinguished road
Please put up pictures after you attempt this lol
Bruscomusco is offline   Reply With Quote
Old 01-07-2010, 09:49 AM   #11
humans can hear down to 20hz. (very few people can hear 15hz) dog whistles are around 22khz, in which human hearing stops at 20khz...which is tweeter land. Subs don't do that kinda frequency
Old 01-07-2010, 10:16 AM   #12
Ian 2000GL LA1
30-32 hz its nice and from the boxes i have built for 15's in that region, they alway come out with a nice flat response.
21" sub?
What is it?
incriminator audio death penalty 21
will do a build log.
Old 01-07-2010, 10:18 AM   #13
25 sq inches of port is to small.
Got port whistle?
Old 01-07-2010, 10:26 AM   #14
Ian 2000GL LA1
Got port whistle?
lol itll probably be 14x14 or so i havent ran it through a calculator yet.
Old 01-07-2010, 10:51 AM   #15
Ian 2000GL LA1
ok had to do some adjusting after i measured box will be 34Wx15Hx29D @ 6.98 cubes tuned to 34 according to the12volt.com, though i would like to run these through WinIDS first, if i can figure out how to get box calculations out of it, and if i can find the specs, i called incriminator audio and there closed becouse they went to the CES show in vegas until tuesday....
Old 01-07-2010, 01:10 PM   #16
Make sure to check the velocity tab...
200 Sq In might still be a bit small.
Old 01-07-2010, 01:33 PM   #17
DAMN 21 inch subs what is the RMS on the sub.
Old 01-07-2010, 11:03 PM   #18
For a 14x14 port size my calc came up with 4.3 ft duct length for 34 hz, 7 cu.ft......what calculator are you using? That would take up over 4 extra cu.ft of space, so I hope it's wrong, I did not recheck the math. But even one cu. ft. of depth would throw the tuning off.
Old 01-07-2010, 11:28 PM   #19
1500 wrms
Old 01-08-2010, 01:15 AM   #20
Ian 2000GL LA1
using the one on the12volt.com and the RE box calculator. at 13.5x7 in getting 94 sq inches. i need the specs from Incriminator audio to punch it in to WINISD to make sure my velocity isn't going to be too much but i have a feeling it will be.
