Old 01-16-2010, 10:23 PM   #1
Blade
Blade's Avatar
Blade is on a distinguished road
Radiator Flush
IS there an how too? I cant seem to find it.
Blade is offline   Reply With Quote
Old 01-16-2010, 10:32 PM   #2
A57
A57's Avatar
A57 is on a distinguished road
Send a message via Yahoo to A57
Talking
Well if your doing it your self then you would drain the radiator, then pull the upper radiator hose put in the garden hose and turn it on about half way to flush the old stuff out...
Or you can go to the oil change shop near you and have them do it with thee machine.
BUILDING A V8 ALERO 2DR
A57 is offline   Reply With Quote
Old 01-17-2010, 07:11 AM   #3
Blade
Blade's Avatar
But there isnt a radiator neck to fill it back up!
Old 01-17-2010, 07:25 AM   #4
huh? you just put coolant into the resevoir and it'll fill the rest of the car. Then use the bleeder valve to get the air out of the system...
Old 01-17-2010, 08:39 AM   #5
yes, the overflow tank is not an OVERFLOW... it's pressurized like the rest of the system...
Old 01-17-2010, 10:48 AM   #6
Blade
Blade's Avatar
Where are the bleeders?
Old 01-17-2010, 11:58 AM   #7
Um....bleeders? I haven't seen any on mine. If it starts growing them, I'm going to get really concerned.
Old 01-17-2010, 01:17 PM   #8
A57
A57's Avatar
well i'll send you some really BIG bandaids to stop the bleeding.....
Yea the bleader screw on the top of the water pump.
Old 01-17-2010, 01:20 PM   #9
ok... maybe its the wrong term... but the little screw valve on the front left of the valve cover. (as per last post... apparently its on top of the water pump. )
...to the left of the oil cap. There is a little vertical black cylinder with a hexnut on top. With the car running, you use a small socket (7mm?) to open it, until coolant leaks out. At the beginning a bunch of air will come out, then bubbles, then just coolant. When its just coolant, tighten it back down, then shut the car off.
Old 01-17-2010, 01:33 PM   #10
A57
A57's Avatar
we have a correct answer....7mm is right and also use a 10mm to hold the bottom part of the bleeder... this is a brass part so dont HEMAN this part....
Old 01-17-2010, 02:30 PM   #11
oh THAT kind of bleeder. Sometimes I forget we're on a car forum
Old 01-17-2010, 02:47 PM   #12
...most times.. its even hard to tell this is a car forum.
