Old 01-21-2010, 07:11 PM   #1
Runaboveit
Runaboveit's Avatar
Runaboveit is on a distinguished road
Exclamation Heater core on a 2001 V6 + few questions...
I searched but didnt find the answers I was looking for.
I am going to attempt to replace the heater core in my 2001 V6.
I have the Chilton (or Haynes.. I dont remember) and it explains how to replace the heater core. I figured it would be a good idea to ask on here first, if anybody has done this before and have any tips?
Question. I noticed some posts I came across said removing the dash, steering wheel, seats, etc. That doesn't seem right. The manual shows everything should be done just by going through the glove box and taking it out through there. I also read online that aleros after 2002 had the dash insides redesigned and it is a lot more involved on those to access the heater core. Can any body else chime in about this?
Also, how do you bleed the coolant bleed screw. You twist the lower part of it or the top?
Thanks a lot guys!
Cody
Runaboveit is offline   Reply With Quote
Old 01-21-2010, 07:28 PM   #2
A57
A57's Avatar
A57 is on a distinguished road
Send a message via Yahoo to A57
Talking
Thanks a lot guys!
Cody
Well cody,
the manual is just a guide and the heater core is in the center(ish) of the dash..there's about (shit) load of bolts that hold the cover and it would help you to remove the glove box and the lower dash cover ..drive side and passanger side...If you want to make it a bit easyer to remove the passanger seat to lay down would hurt if you a big guy like i am...
Just take you time and make sure you take pics if this is your first time. it easy to use them as a reference to put things back...
good luck...
the bleeder( NEEDS A BAND AID?) LOL use a wench to hold the lower nut and use a 7mm to open the wep hole bolt...
BUILDING A V8 ALERO 2DR
A57 is offline   Reply With Quote
Old 01-22-2010, 12:19 AM   #3
Runaboveit
Runaboveit's Avatar
Hey, thanks for the info.
So, I shouldn't have to pull the steering wheel should I?
Old 01-22-2010, 01:37 AM   #4
elpuas3000
elpuas3000 is an unknown quantity at this point
http://www.youtube.com/watch?v=ngi2c...eature=related
check this out... lolz
elpuas3000 is offline   Reply With Quote
Old 01-23-2010, 10:26 AM   #5
A57
A57's Avatar
Well if you need to.. ic no reason to do so. Be Careful make sure you disconnect the battery so you don't pop the air bag, or you can pull the fuse.
