Old 03-20-2010, 01:44 PM   #1
Spike440
Spike440's Avatar
Spike440 is on a distinguished road
2.4L automatic SHIFTS TOO SOON
My 01 alero shifts extremely fast when you stomp on it, but the rpms stay at about 2200 ( never more than 3k ) but if i go through the 1-3 the acceleration stays at a normal rate. I have no idea what is causing this I dont believe its the engine because i just had an engine out of a sunfire dropped into it and it did the same thing before. I might not be describing it specific enough but maybe I can take a vid of it on my way to work or something then you can see it very clearly. Let me know if any of you have any ideas, its been bugging the crap out of me! thanks
also this forum is very helpful and awesome, ive been on here nonstop since last night haha
Spike440 is offline   Reply With Quote
Old 03-20-2010, 01:48 PM   #2
So you're saying at WOT it shifts at 2200 instead of 6450?
Old 03-20-2010, 01:51 PM   #3
Spike440
Spike440's Avatar
Im assuming WOT is wide open throttle, so yes, it shifts at a very low rpm at wide open, and accelerates slower than my mercury tracer that runs on 3 cylinders. XD
Old 03-20-2010, 02:29 PM   #4
Spike440
Spike440's Avatar
think Its a tranny problem? I tried googling a ton of different things but nothing comes up for the problem im having
Old 03-20-2010, 03:53 PM   #5
Chris2000
Chris2000 is on a distinguished road
Did you try cleaning your throttle body out? Simple things like that can have a huge effect.
Chris2000 is offline   Reply With Quote
Old 03-20-2010, 04:33 PM   #6
Spike440
Spike440's Avatar
It did this when i purchased it and the motor blew so I had a motor from a sunfire dropped into it. When they drop a used motor in do they use the original throttle body, or the one from the other engine? im not sure on this but no I havent cleaned the throttle body out. If I put the car in 1 and accelerate it will accelerate quickly, i just have to push the shifter into 2 and then to 3, then to drive to get to overdrive, whereas if its in drive and i floor it, it will hit 2nd at 30, then overdrive at 40
Old 03-20-2010, 04:50 PM   #7
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
is it throwing any codes? this sounds like either a problem in programming or compatibility from the new engine and the old transmission.
Old 03-20-2010, 05:06 PM   #8
Spike440
Spike440's Avatar
It did it even with the old engine though. and the service engine light is not on.
Old 03-20-2010, 06:05 PM   #9
Spike440
Spike440's Avatar
http://www.youtube.com/watch?v=xfGu7kvvkwM
this is what it is doing...
Old 03-20-2010, 08:30 PM   #10
Weazel
Weazel's Avatar
Weazel is on a distinguished road
Send a message via AIM to Weazel
Did you try resetting it?
Weazel is offline   Reply With Quote
Old 03-20-2010, 08:49 PM   #11
Spike440
Spike440's Avatar
how would you reset it? and reset what?
Old 03-20-2010, 08:54 PM   #12
unhook the battery for a night
Old 03-20-2010, 09:54 PM   #13
Spike440
Spike440's Avatar
I had a new battery put in it when i bought it, would it have to be unhooked for more than 30 mins?
Old 03-20-2010, 10:14 PM   #14
1 hour or more
Old 03-20-2010, 11:43 PM   #15
Spike440
Spike440's Avatar
both terminals? i was thinking about it and the battery was unhooked for about 2 days while the replacement motor was being put in.
Old 03-20-2010, 11:54 PM   #16
disconnect the catalytic converter flange and see how it drives after that (ridiculously loud obviously but try it)
Old 03-20-2010, 11:54 PM   #17
watch out john deere alero commin down the street
Old 03-21-2010, 07:32 PM   #18
Spike440
Spike440's Avatar
It doesnt downshift either, if im in overdrive and floor it no matter the speed it stays in overdrive.
Old 03-22-2010, 09:17 AM   #19
Th0r
Th0r's Avatar
Th0r will become famous soon enough
Pull the codes. Your SES light is on. That usually means you have a problem...
GX Coupe
Dropped and Blown
Th0r is offline   Reply With Quote
Old 03-22-2010, 10:09 AM   #20
Spike440
Spike440's Avatar
SES light isnt on, the TRAC OFF light is on, and "low washer fluid" lol i tried to zoom in the camera so you could read it.
