Old 03-29-2010, 11:47 AM   #1
Kilroy
Kilroy's Avatar
Kilroy is on a distinguished road
Wheel good question
Would C5 Corvette rims have the same spacing so as to fit on an Alero?
Kilroy is offline   Reply With Quote
Old 03-29-2010, 12:07 PM   #2
bentiac
bentiac's Avatar
bentiac is on a distinguished road
I believe the offset on those is around 55+ ... ours needs to be between 35-45 so no.
GS - 01 Alero Coupe - MT, CG-lock,Front/rear strut tower brace,WAI,Fidanza Short throw Shifter and custom short throw clutch, AGX adjustable struts and mounts, Dropzone Springs, speedbuilt front sway bar, Toyo R888.
CS - 06 RX8 - Special Edition Shinka, 285 Hoosier A6.
bentiac is offline   Reply With Quote
Old 03-29-2010, 05:18 PM   #3
Kilroy
Kilroy's Avatar
BUmmer, cause a local guy has a good deal on a set.
Old 03-29-2010, 05:53 PM   #4
plus I believe they are 5x4.75 which would not work.....
Old 03-29-2010, 06:27 PM   #5
bentiac
bentiac's Avatar
The best OEM rims that fit Alero IMO are the Grand Prix GTP 17 inch ones.
Old 03-29-2010, 06:32 PM   #6
i say g35 17s with the proper offset, they have two types so you have to make sure......
Old 03-29-2010, 07:37 PM   #7
colonel6632
colonel6632's Avatar
lol. need another set of rims?
Old 03-29-2010, 09:13 PM   #8
Kilroy
Kilroy's Avatar
No, just an idea.
Old 03-30-2010, 02:11 AM   #9
You would need wheel adapters/spacers. About 1.5" if you use 4 front wheels but definitely doable. The offset on them makes the outside of the wheel in just about the same position as stock, but they're 8.5"/9.5" (Z06 is an inch wider I think) so that needs to be compensated for.
I have C5 mags on my Beretta...
Old 02-06-2013, 11:44 AM   #10
CrazzyCavanaugh
CrazzyCavanaugh is on a distinguished road
Offset New Wheels
im kinda in a hurry and didnt wanna go looking through the forums for what i need
but i have 235/40's 18" rims on my car and i dont know the offset
but i wanted to order the same size wheels but with a 40 offset, will they fit/rub at all ? thanks
CrazzyCavanaugh is offline   Reply With Quote
Old 02-06-2013, 12:42 PM   #11
the fifteen seconds that it took me to find this was a HELL of a lot longer than the almost hour it took you to get a response...what were you looking for, offset, so search that, I told you like 3 days ago that it was the most recent thread about it, does today look like 2010 i didn't think so, it wouldn't be quite so damn annoying that I have to show you the thread to view if I hadn't already told you the exact thread to look at to find the information that you needed
here is the thread
http://www.aleromod.com/forums/showt...ghlight=offset
