Old 05-20-2010, 08:26 PM   #1
MotorCity
MotorCity's Avatar
MotorCity is on a distinguished road
need audio help
my amp
http://www.wigix.com/item/83490/Soun...nnel-Amplifier
wanted to get these
http://www.frys.com/product/6251100?...H:MAIN_RSLT_PG
Will i blow them ? i have $170.00 and a 10" sub box with 2 cooked JBL pieces of crap that are 10 years old still in it. should i jus go with this or get new 10" subs ?
thank you
I am beyond help...
MotorCity is offline   Reply With Quote
Old 05-20-2010, 08:56 PM   #2
Is the box sealed or ported?
What size is it- lets calculate air space.
TBH those speakers are not that great. I can get you a pair of speakers that are better all around for less.
Old 05-20-2010, 09:07 PM   #3
MotorCity
MotorCity's Avatar
Are there 10 inch subs that can beat it for that price?
I am beyond help...
Old 05-20-2010, 09:16 PM   #4
MotorCity
MotorCity's Avatar
alpine type R ? 10"
I am beyond help...
Old 05-20-2010, 09:19 PM   #5
It wont take much to beat those subs...
http://americanbassusa.com/front/sho...aspx?fileid=65
Thats what I would recommend. You have the right power for them too.
Old 05-20-2010, 09:22 PM   #6
MotorCity
MotorCity's Avatar
So i am going to go with a set of these Alpine SWR-1043D 10"
* Peak: 1800 watts
* RMS: 300-600 watts
I am beyond help...
Old 05-21-2010, 12:55 AM   #7
Type-Rs are my go-to sub whenever I want pretty loud bass for cheap. In the right bow they get loud, and are pretty tough to blow up.
You should enjoy them.
Old 05-21-2010, 04:12 PM   #8
MotorCity
MotorCity's Avatar
okay good i hope they hit good with my amp
I am beyond help...
Old 05-22-2010, 03:17 AM   #9
Cashdollar2009
Cashdollar2009's Avatar
Make sure you understand ohm loads before you hook anything up. With that cheap-o amp, anything under 4-ohms will fry it real fast... :/
Under construction...
Old 05-22-2010, 12:53 PM   #10
MotorCity
MotorCity's Avatar
my cousin is a audio installer he is going to help me out. but, i set the switch to 4 ohm.. but any advice wouldnt hurt or a link to where someone explains audio set up. just in case
I am beyond help...
Old 05-23-2010, 11:16 AM   #11
negolien
Make sure you put in some sound deadening like dynamt or something 1st off. Hit the trunk lid and the flat piece facing our where the emblem is on the outside kinda where the license plate would be. I have that box pushing 500rms at 2ohms and it's good I would be careful running 4 ohms into em though. After looking I would say that's way way overpowered for them speakers lol. There 1000 watts peak I think for the box and like what 250 a piece?
Old 05-24-2010, 05:11 PM   #12
MotorCity
MotorCity's Avatar
I changed my mine got Alpine type R's 1800watt max 700-900rms
I am beyond help...
Old 05-24-2010, 06:33 PM   #13
Cashdollar2009
Wtf? 4-ohms is a higher resistance that 2-ohms therefore your speakers would see theoretically more output at the lower load of 2. Good output, that depends on what your amplifier is built to perform at. Some amplifiers, especially down at that level are only rated at 2-ohms stereo and 4-ohms mono. When you drop the ohm load down to 2-ohms mono, due to wiring configuration as well as speaker selection, your amp will go *poof*. Don't spread stupid. Not trying to be mean, but there are already too many misinformed people when it comes to car audio.
And sound deadening... If you are running 500 watts, don't even worry about sound deadening. It would cost more to deaden it than the rest of your audio gear is worth... :/
Old 05-24-2010, 06:40 PM   #14
The trunk lid will still rattle like a mofo! Just get a can of spray foam and throw on the lid. And agreed^^
Old 05-24-2010, 06:44 PM   #15
Cashdollar2009
True true. You will notice the piece that has the "Alero" letting on it on the trunk lid will give you a bit of rattle. Even off of 300rms. Do as pimp said and you should be fine. Once you start getting into a bit more sound pressure, then deadening might actually be a bit more of a priority. But, for now, that trunk trim piece would really be about it.
Old 05-24-2010, 07:34 PM   #16
MotorCity
MotorCity's Avatar
Thanks for the helpful info.. besides all the vids ive watched on you tube about amp tuning(ive done it b 4 but with a lower watt mono amp so its going to be little different) any tips that aren't mention that often but prove vital ? and if your going to say use the search bar you noob then dont bother.. i know they are there, i have skimmed through them, jus making sure no minute detail is overlooked here
I am beyond help...
Old 05-24-2010, 10:41 PM   #17
Cashdollar2009
I've been there, i'm not going to use the "search bar noob" line on you.
You got PM.
