Old 07-02-2010, 09:55 PM   #1
McMarcus
McMarcus's Avatar
McMarcus is on a distinguished road
Hid Problem!
I hooked up everything properly on my HID's, i hope so atleast. And they wont light up, i dont have high or low beams, but still have my blinkers. It also cut off my Fog lights, and my check engine lights and my light for my High beams stay on and i cant click them off. I thought i blew i fuse, but i checked them and they are all fine. Any suggestions? I bought my HID's from DDM Tuning and they are 55W 9006, 8000k.
-8000K DDM HID Kit
--Tinted Tails
---AVS headlight covers
----MTX SUBS, Pioneer Head-unit.
---Blue LED's
--White-painted Bezels
-Clear Corners
--More to come.
McMarcus is offline   Reply With Quote
Old 07-02-2010, 10:05 PM   #2
have them wired backwards?
Old 07-02-2010, 10:11 PM   #3
McMarcus
McMarcus's Avatar
I dont think so, how would it be backwards? after you said this i flipped the plug-ins inside my headlight houseing (one that hooks up to stock bulb) and then i flipped the one going to the ballast.
-8000K DDM HID Kit
--Tinted Tails
---Blue LED's
-Clear Corners
--More to come.
Old 07-03-2010, 06:19 PM   #4
Monza
Monza is on a distinguished road
To have all of those problems the BCM likely is pissed. I would put everything back original and see if the problems go away. If not, unhook the battery for a half hour and see if the BCM will reset. If not, the BCM may be toast.
If everything resets OK then begin this time with a plan for the correct polarity for everything before you try to fire them up again.
Monza is offline   Reply With Quote
Old 07-04-2010, 02:12 AM   #5
The BCM is irrelevant if the headlight switch is turned on. Did you unscrew any ground splice packs by chance?
Old 07-04-2010, 07:58 PM   #6
XanderWiFi
XanderWiFi's Avatar
Flip the on switch? : P
Old 07-04-2010, 09:52 PM   #7
alero_bmxer
alero_bmxer's Avatar
do you have the headlight harness plug plugged in?
Old 07-04-2010, 11:13 PM   #8
bizarre179
bizarre179's Avatar
bizarre179 is on a distinguished road
Send a message via AIM to bizarre179
Flip the plug around. It has tabs on it, but ignore them. Thats what I did and they worked. The polarity is wrong.
kim<3
http://www.cardomain.com/ride/2981709
bizarre179 is offline   Reply With Quote
