10-18-2010, 04:14 AM
Modding my 2001 Alero
10-18-2010, 04:16 AM
10-18-2010, 05:47 AM
very nice work
Originally Posted by Oldsnut
Originally Posted by tipnitty
10-18-2010, 08:26 AM
Welcome, glad to see you are jumping right into things. Is that your shop? I see some Hoosier slicks in the background.......
10-18-2010, 12:55 PM
nice pics
10-18-2010, 02:23 PM
what is the little filter under your overflow reservoir??
and why retrofit things? that engine has tons of aftermarket parts, as well as probably tons of junkyard versions...
10-18-2010, 02:27 PM
I forget what its called lol, but my civic has the same thing, it feeds into the stock airbox, when I put the intake on my civic, I just fed it in through a bung with a hose, was throwing a code without it in, so I'm guessing it has something to do with the IAT
10-18-2010, 10:59 PM
Both questions that I have as well.
Props on the work
10-18-2010, 11:16 PM
PCV maybe? or is that another thing they didn't bother to put on the LD9, lol.
1987 Honda Rebel 450
10-19-2010, 04:04 AM
Hey, I'm back! Sorry, I thought I was subscribed to this thread.
Originally Posted by sleepyalero
very nice work
Thanks a lot!
That's actually Cozzolino Motorsports here in Indianapolis. They do amazing work with a chassis jig, a dyno, lots of welding and painting equipment, and incredibly competent people.
Originally Posted by lord2heart
nice pics
Thanks!
Thanks for asking - I forgot to mention it. The filter is for the PCV. I routed the PCV hose to the reservoir and put a PCV valve on it plus a filter after that. And of all the things that were done, what was retrofitted? I'd gladly put on something made for the LD9 if it cost as much or less than just backyard engineering it.
You're probably talking about the PCV, which on a Civic (and I'm not sure why not on the LD9) is an issue if it's unplugged. Neither one has a mass airflow sensor, so the PCV being kept in there is very helpful on startups.
Props on the work
Thanks a lot!
Interesting... What else, aside from the MAF, was left out?
10-19-2010, 08:26 AM
So i'm assuming you work for them then? Are you a painter? fabricator?
10-19-2010, 09:01 AM
Some LD9's came without an EGR valve, which is extremely odd because I was under the impression those became mandatory in the early 90's.
10-19-2010, 11:48 AM
EGRs are a waste, first thing I did was delete that crap.
10-19-2010, 02:23 PM
Actually, I just take my cars there. I'm supposed to help them redo their website since site work and site hosting are my means of self-employment. I'm in college now for Motorsports Engineering, which is Mechanical Eng with an internship thrown in. Also, I went to two colleges one semester, the other being a community college where I went through welding courses. At Cozzolino Motorsports, I welded one hanger to my exhaust pipe while Pete Cozzolino was out painting a racecar.
The EGR valve and cat are sometimes excluded on post-1974 cars as long as they're non-catalyst certified, IIRC. Also, some new cars with variable valve timing can keep the exhaust valve open just long enough on the intake that some exhaust gas is worked back into the combustion chamber. This is a cleaner process than dumping exhaust into the intake, and it doesn't require a valve. I'm not sure if any LD9 has VVT, or but that's just one more way to get around an EGR. Also, an EGR makes no sense for turbo cars and plus the slight backpressure at idle and slight throttle, when the EGR valve is open, makes up for the lack of one. Probably no LD9 came turbocharged, but I'm just guessing anyway.
After deleting my EGR on my other car, a 1999 Pontiac Bonneville, I had no more need to clean the intake. I was working on my friend's 2001 V6 Mustang, and his EGR delete took some retuning because Ford doesn't make up for a lacking EGR valve nor accounts for it using the MAP sensor for some reason. I love GM!
Dodge Neon ignition coil, S-10 plug wires, modified intake, K&N drop-in air filter, and a Magnaflow cat
10-19-2010, 03:04 PM
Wow, I didn't know about all that stuff to avoid and EGR, cool to learn new stuff.
