Old 11-19-2010, 10:03 AM   #1
Hectic
Hectic is on a distinguished road
I'm stumped.
I've been trying for the past hour and a half to try and figure out how I'm gonna connect my power wire to the positive terminal. The ring connectors I have are trash, and won't clamp down onto the wire at all. I don't wanna stick the wire into the terminal.
I'm completely lost, and have no idea what to do.
1999 GX LD9 Sedan -- RIP 'ho
Hello 2012 Sonic LT
Hectic is offline   Reply With Quote
Old 11-19-2010, 10:34 AM   #2
Buy new connectors.
Old 11-19-2010, 10:45 AM   #3
MattismodderX
MattismodderX's Avatar
MattismodderX is on a distinguished road
Send a message via AIM to MattismodderX
is this the right kind?
http://www.allelectronics.com/make-a...-PLATED/1.html
Officially addicted to bass.
MattismodderX is offline   Reply With Quote
Old 11-19-2010, 11:56 AM   #4
Hectic
Finally got them to work. But now, can't find a good spot to mount the fuse, I don't got much room between the airbox and the battery, so I may just strap them down.
Hello 2012 Sonic LT
Old 11-19-2010, 12:14 PM   #5
MattismodderX
you get more (steady direct) power w.o a fuse. i forget the details but it slows down the draw of power from the battery a bit
Old 11-19-2010, 01:38 PM   #6
Hectic
I got the power back, but I can't get the headunits to go back in, the RCA cables are hitting a metal thing at the back. Help!
Hello 2012 Sonic LT
Old 11-19-2010, 01:48 PM   #7
MattismodderX
i took a pair of heavy duty plyers and ripped the plastic trim out from the back inside of the headunit area brute force style so the 6 rcas would fit.
Old 11-19-2010, 02:32 PM   #8
You have to cut the back with our cars when adding an after market headunit.
This is the adapter you could have gotten if using a side post battery
Then you could have gotten these terminals and soldered the wire to it.
Then a 100amp inline fuse like so
Old 11-19-2010, 05:05 PM   #9
Stickybuddz420
Stickybuddz420's Avatar
Stickybuddz420 is on a distinguished road
Did you just suggest not using a inline fuse on the power wire???
B4 Cleared Corners/Fog Light Removal
No More Cobalts - 2 12" Punch HE2's
1100W BOSS CHAOS Mono Amp
Stickybuddz420 is offline   Reply With Quote
Old 11-19-2010, 05:58 PM   #10
widbyj
widbyj's Avatar
I call BS on this. A fuse will NEVER interfere with the proper flow of electricity until it fails for a reason. There is virtually NO resistance nor capacitance in a fuse to delay the power in any way.
EVERY power feed should have an appropriately sized fuse as close as possible to the power source.
FYI - My degree is in Electrical Engineering/Computer Sciences
Old 11-19-2010, 10:45 PM   #11
02AleroEco
02AleroEco is on a distinguished road
Send a message via AIM to 02AleroEco
And to add this this true statement, should there be a powerspike or what ever or a short at the battery. The inline protects your amp or subs from being damaged and speakers / deck aswell.
also i give thumbs up, im a computer degree also and i plan on a masters, plus possibly a BA in Crim Justice
02AleroEco is offline   Reply With Quote
Old 11-19-2010, 11:31 PM   #12
Hectic
I got everything sorted out and hooked up.
I got the connectors to fit on the wire, and the battery terminal, I just drilled the hole a little bigger.
For the RCA's I just bent them down a bit so it would fit.
Now I need to find the best setting on my amp / head unit.
Hello 2012 Sonic LT
Old 11-20-2010, 12:49 AM   #13
That works well, but I have a double-stacked battery terminal with a longer bolt.
Makes for a cleaner looking install in my opinion.
Old 11-20-2010, 02:03 AM   #14
Cashdollar2009
Cashdollar2009's Avatar
Why are you bending your RCA's?
And as for amplifier settings:
LPF: 80-100Hz
Bass Boost: Minimal-None in most cases.
Gain: -Download a 50Hz test tone.
-Use the formula ---> V=sqrt(watts*ohms)
- Attach dmm to + and - terminals on amplifier. (after unhooking subwoofer.)
-Play 50Hz tone at 75% volume. Turn gain up until you reach the voltage you acquired by using the formula above.
-Shut everything off and reconnect your subwoofer.
You can download the 50Hz tone here:
http://ampguts.com/cmps_index.php?pa...udio_downloads
Do what you feel is necessary at your head unit and enjoy.
Under construction...
Old 11-20-2010, 08:59 AM   #15
Hectic
LPF: 80-100Hz
I didn't bend the actual metal part, but the plastic at at the cable.
I'll probably not adjust my amp like that as I don't have a dmm. I'll adjust it by ear as best I can.
If I were to use a dmm, what watts and ohms would I use? The subs or amps rms or peak? For ohms, will it be whatever I will have the speakers wired as?
Say I had 2 300 peak, 150 rms 4 ohm subs wired in to 2 ohms, and the amp is 150 rms and 300 peak at 2 ohms.
What would I use?
Hello 2012 Sonic LT
Old 11-20-2010, 09:23 AM   #16
That.... probably will not end well. And by probably.. I mean...
.......................__ ............
......<ROFL ROFL ROFL ROFL>.
................... __\||/____......
..\ \_...........|--|---|..\\ ....\....
../ L \____,/-------\___\___\
.|LOL|-------------O----- ----,\..
..\ L /______,---''-----------, /...
../ /.............\_________ ,/....
.//.............____//___ __\\__/.
I really hope I'm reading that wrong.
Old 11-20-2010, 09:47 AM   #17
02AleroEco
I am taking it as he is not 100% sure on what he is doing even though its a learning experience.
BUT drilling into a battery? i hope too that was read wrong. Cuz i mean as it was said in an earlier post, you can get longer terminal bolts, OR an even better idea is to get larger ring connectors to fit over stock terminal
Old 11-20-2010, 09:52 AM   #18
Hectic
No, I drilled the hole on the connector bigger. Should have worded that a little better before. I'm not that dumb lol.
Turns out that I have a multimeter. But I don't know what to set it to. It's a micronta from radioshack, it's pretty old.
Hello 2012 Sonic LT
Old 11-20-2010, 11:13 AM   #19
MattismodderX
indeed sir. the fuse adds an insanely small amount of resistance to the power. in the SPL world it adds like .5 to .2 db without a fuse. and every db counts. of course if youre not into that kinda shit then fuse it. also a lot of amps have built in fuses just for that reason. double fused is overkill imo
Old 11-20-2010, 11:22 AM   #20
depends on what you want to test... ?
