01-04-2011, 10:50 PM
air ride question
so ive looked up other threads about air ride but i was wondering if i was to buy a kit for a cavi would it bolt up?...i dont mind custom work i has a s10 before i got my alero that had shaved gate, custom roll pan, and had 5/6 drop but for air ride id feel safer bolting it on
01-04-2011, 10:57 PM
no a cavi is a j-body, they are not compatible
compatible vehicles are the grand am and the malibu
01-04-2011, 11:16 PM
do you know anywhere that sells a decent kit for them such as suicidedoors.com and also can i see some pictures of bagged aleros?...if you want whore it up with pictures
01-04-2011, 11:19 PM
well i know ricerburner2006 is selling a set of bags from his GA
http://www.aleromod.com/forums/showthread.php?t=33111
as far as pics of bagged aleros look up bdyman, jgentry, pimpalero, Fi-alero...I'm sure there's more I'm forgetting
01-04-2011, 11:27 PM
i feel really dumb but how do i see pictures of there cars?
01-04-2011, 11:35 PM
01-04-2011, 11:41 PM
thank you..and what body kit is on the white one i like it alot more then the andys one
01-04-2011, 11:42 PM
AED, it was discontinued, and near impossible to find...
01-04-2011, 11:44 PM
oh that sucks ![Sad](images/smilies/smilies/sad.gif) they should start re making it...looks very agressive and good
01-05-2011, 12:43 AM
You should definitely jump on riceburner2006's air kit. Amazing deal!
01-05-2011, 01:59 AM
yup ... Add me and NoSweat83 to that list too ...
Also, I don't think anyone has mentioned the other two I know ... Don't remember screennames though ... An orange (actually think it was callled Tangelo) and then a red / grey two tone.
01-05-2011, 03:50 AM
what kits does everyone have? and if i had the $ right now id be allover it but i dont ![Sad](images/smilies/smilies/sad.gif) and does an alero fully lay out with just bags or do you have to do mods...like i know with my truck you had to c notch the frame
01-05-2011, 04:39 AM
The set-up I had for my air horn was a 5 gallon tank with a 280c Viair compressor. That could power an air ride for an Alero no problem, althought I think some guys had 2 280c's
I still have the 280c but a 4 gallon pancake tank tucked away for more trunk space ![Wink](images/smilies/smilies/wink.gif)
01-05-2011, 07:23 AM
A stock alero won't lie flat out...however I do believe if you've got the AED or AAS kit it will
01-05-2011, 09:40 AM
i had hydraulics on mine. with 225/40/18 tires they were rubbing on the wheel-wells when it was lay'd out.
![](http://memimage.cardomain.com/ride_images/1/1646/1341/4113170052_large.jpg)
01-05-2011, 10:31 AM
1 compressor is really not enough for any air ride setup, unless you do not touch the switches at all. your compressor would most likely overheat before it filled a 5gal tank from 0psi to 160+ PSI
![](image.php?s=5b783fa04246788505074e280a9b9fc8&u=3572&type=sigpic&dateline=1269488373)
01-05-2011, 01:09 PM
This. I run two 480's with a 5 gallon tank on my Tacoma and that takes about 4ish minutes to fill up to 157 psi from dead empty.
I'm a minitrucker-every build is a budget build
01-05-2011, 04:51 PM
i didnt mean looks as in lay flat out but as in pinch weld/unibody laidout
01-06-2011, 01:33 AM
Oh, OK. The guy that sold it to me said it could power an air ride for the Alero. I bought my set-up from Forbidden Kustoms and they did Joel's car, so that's where I got my info from ![Wink](images/smilies/smilies/wink.gif)
01-06-2011, 03:30 AM
it could power an air ride, but it would be unrealistic. i have 2 viar 380c's and it takes a long time to fill the tank, although i have a 185psi switch.
