01-23-2011, 11:53 PM
Random Hesitation @ different speeds
Ok so Ive looked around the forum and found 1 thing that i thought was causing the hesitation (fuel filter) got that changed and it still does it. Took it to a shop and the guy there couldnt find a thing wrong saying it could be bad gas or water vapor? Drove it back and forth for 2 days nothing happened then the next day it happened a few times at different speeds and at different pressures on the gas petal.
So whats the deal? Any clues as the where to look next?
01-24-2011, 12:28 AM
dying fuel pump possibly, or sticky injectors. There's a whole list of things it could be
01-24-2011, 04:47 AM
Had the same problem. Could never figure it out.. do your rpms jump too? Mine stopped it a month ago hasn't done it since. Its weird it did it for about 4 months then stopped.
Originally Posted by Oldsnut
Originally Posted by tipnitty
01-24-2011, 09:57 AM
Never heard of a ful pump acually kicking it on an Alero, but Im sure its possible. What would make an injector sticky to the point of failing to delilver gas? And how would u be able to tell which one? Or could it be the electrial connection going bad to the injector. But wouldnt that just make it just misfire??
01-24-2011, 09:58 AM
Somewhat ya the rpms do go up a bit. Mine is cold stock so Im not sure If you and I are having the same issues.
01-24-2011, 11:17 AM
a sticky injector could have just been caused by dirty fuel, if its just a little sticky and not completely stuck it would take slightly longer for it to open, and therefore a delay in receiving the fuel, and also less fuel to be delivered since the injector isn't open for as long
01-24-2011, 11:27 AM
He said it's at certain pressures on the throttle, could it be something to do with the TPS? Just a thought.
1987 Honda Rebel 450
01-25-2011, 12:34 AM
I dont know what motor you have, but on the 3400, ive gone through two pumps, and have a spare ready. They definately do go out on aleros. My random misfire ended up being bad wires, one was taking 14500 ohms, the new one was at 3000 ohms.
"How did you MELT the spark plugs!?"
01-25-2011, 08:13 PM
GEEZ!
@Op... I would deff check your TPS. Are you not throwing any codes?
01-25-2011, 11:09 PM
The guy before me must have gotten very cheap wires, they looked pristine and new, but alas, they sucked
01-27-2011, 12:30 AM
well I finally got an answer to why my engine was stalling and hesitating. The ICM has gone belly up. So I will be replacing that along with 3 new coil packs and spark plug wires to boot.
All at the sum of 240$.
01-27-2011, 12:55 AM
are you running a K&N filter if so clean your Mass air flow sensor thats caused weird surging in my car
parts so far: 10000k hid heads and fogs, alpine INAW900, bluetooth, backup camera, alpine mrp-m2000, 18fi btl, 270amp mechman alterntor, 2 Redtop Batt's, all LED lights and color changing signals white/amber (every bulb other then dummy lights) and limo back 3 and 20% in the front and tinted tails
check out my car http://www.youtube.com/user/scott192
Well I know my car is female because she was bleeding for 7 days and didnt die!
01-27-2011, 12:56 AM
haha i must read^^
