Old 02-03-2011, 07:59 AM   #1
Jroc26
Jroc26 is an unknown quantity at this point
Cruise control switch lights
Has anyone replaced these or are they even replaceable? I noticed all the lights on my cruise control switches are burnt out except for 1 and would like to replace them if possible. If they are replaceable what bulb is it and how do you do it? Thanks
Jroc26 is offline   Reply With Quote
Old 02-03-2011, 09:02 AM   #2
zzyzzx
zzyzzx's Avatar
I suspect that these bulbs are the type that you find at Radio Shack that look like this:
Old 02-04-2011, 01:25 PM   #3
Whitetigerboi83
Whitetigerboi83's Avatar
Whitetigerboi83 is an unknown quantity at this point
Send a message via AIM to Whitetigerboi83 Send a message via MSN to Whitetigerboi83 Send a message via Yahoo to Whitetigerboi83
yeah its a PITA to get those off
take the steering column cover off be-careful the plastic clips break really easy
take the horn/airbag off need a torx bit
then the switch modules
i would unplug your airbag fuse and relay's or just the battery and let the car sit for a bit 5-10 min if you unplug/plug it back in wrong and its still charged could blow and that wouldnt be good.
Whitetigerboi83 is offline   Reply With Quote
