Old 03-01-2011, 07:25 PM   #1
cam timing
Is there a way to check the cam timing without tearing the engine apart
Old 03-01-2011, 07:43 PM   #2
take off the timing cover
Old 03-02-2011, 01:42 AM   #3
At which point it's time to change the timing chain
Old 03-02-2011, 12:57 PM   #4
How do I do all that?
Old 03-02-2011, 02:05 PM   #5
drain the oil and coolant. Remove the power steering pump, water pump, crank pulley, belt, tensionor, and maybe the a/c compressor. then remove the 20 or so bolts holding on the timing cover.
Turn the engine over manually until the mark on the crank gear is straight up which is TDC (top dead center) and see if the mark on the cam gear lines up with the crank gear mark.
