Old 04-02-2011, 11:00 AM   #1
slownlow43
slownlow43's Avatar
slownlow43 is an unknown quantity at this point
door lock and trunk issue
Ok guys, I'm asking for help again. Just picked up a 99 Alero to replace my 02 and the power door lock, remote trunk, and fog lights don't work. When you press the buttons manually or with the keyless remote you can hear clicking under the dash like its trying to perform its function. Has anyone else experienced this issue?
I'm a minitrucker-every build is a budget build
slownlow43 is offline   Reply With Quote
Old 04-02-2011, 01:05 PM   #2
The only thing shared in common between these functions is that they're controlled by the BCM, but if the relays are clicking, then that's working.
Does it only not work right when you use the keyless entry?
Old 04-02-2011, 04:14 PM   #3
Vella's Alero
Vella's Alero's Avatar
Vella's Alero is on a distinguished road
Not to thread jack but I have the exact same problem. Only difference is my trunk will only work with my remote starter fob but nothing in the car will trigger it. I'm curious to hear any ideas.
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
Vella's Alero is offline   Reply With Quote
Old 04-02-2011, 05:46 PM   #4
i would get a multimeter and try to test the lines while you hit the buttons and see if/where there is a short/break in the lines for those solenoids.
Old 04-03-2011, 08:40 PM   #5
slownlow43
slownlow43's Avatar
It ended up being the relay for each of those functions. I wasn't aware they had their own relay before I posted this thread. Thanks for all the help.
Old 04-04-2011, 06:02 AM   #6
Vella's Alero
Which relays are they and where are they located?
Old 04-04-2011, 08:09 AM   #7
slownlow43
slownlow43's Avatar
I believe all three were located in the drivers side interior fuse panel.
