Old 04-08-2011, 10:16 PM   #1
Jroc26
Jroc26 is an unknown quantity at this point
Any way to get into trunk with no key and no battery power?
I was at the junkyard today grabbing a few things for the car and found an alero my colour with the spoiler, I want the spoiler from the car BUT the trunk is closed . Does anyone know of any ideas to get into the trunk? I was thinking I could be a and go through the backseats but then I remembered the only was to fold the back seats down is through the trunk What a stupid idea that was lol
Jroc26 is offline   Reply With Quote
Old 04-08-2011, 10:22 PM   #2
It's a 60/40 fold seat, right? Reach through the part where the seats split and grab and pull the release handle.
It's worked for me on a Cobalt once.
Old 04-08-2011, 10:24 PM   #3
strtrydr
strtrydr's Avatar
Depending if all the fuses and relays are there and if you have a great multimeter like a fluke then you can use the fluke to provide 12v needed to pop the trunk ... This is all just an idea though as I have never tested it out but in theory it should work.
Old 04-08-2011, 10:31 PM   #4
Jroc26
Good call on both you guys, I think the fuse box had been taken out but I'm not 100 percent sure, I'll go back tomorrow and try both ways.
Old 04-08-2011, 10:37 PM   #5
When I first installed my junkyard trunk, I accidentally folded up my seats, and the button wasn't working, and obviously my key was not made for that trunk. It's damn near impossible to get the latches through the seats.. I actually ended up lubing the key a bit and wiggling it like crazy and it actually opens the trunk lock..
So if you want to get into someone else's Alero just coat your key with lube and wiggle it a ton.
Old 04-08-2011, 10:40 PM   #6
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Not that it helps you at all but i put small pieces of dynamat around the latch of the seats so they don't lock in place. that way if i want moar bass, i can just reach back and pull the seat down
Done lost my mind
Old 04-08-2011, 11:15 PM   #7
Greencoupe2.2
Greencoupe2.2's Avatar
Greencoupe2.2 is on a distinguished road
Simple remove your battery, and connect it to the junked car.
Greencoupe2.2 is offline   Reply With Quote
Old 04-08-2011, 11:39 PM   #8
ugh.... My mind went completely south on this one....
Old 04-08-2011, 11:42 PM   #9
Jroc26
The whole front end of the car is gone, fuse boxes gone and trunk pop button gone lol
Old 04-08-2011, 11:50 PM   #10
If you just want the spolier, take a flat head screwdriver and push it into the lock, once it's all the way in, turn it, then remove said screwdriver
Old 04-08-2011, 11:51 PM   #11
Greencoupe2.2
first try what clutch said and if you cant fit your arm through use a metal rod or coat hanger to release the seats.
Old 04-09-2011, 07:28 AM   #12
i'd probably try ripping the wires out for the trunk release button, and bridging them with a 9V battery.
Old 04-09-2011, 07:34 AM   #13
Jroc26
I actually thought about that too, I might have to pick up a battery on my way and give it a go.
Old 04-09-2011, 11:13 AM   #14
probably better to put wires already on the battery, then just push them into the connector for the switch, and hit it. Instead of cutting them.
... but i'm all for being courteous first...
Old 04-09-2011, 04:49 PM   #15
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
Rip the bumper off, there will be 2 bolts in the middle, remove said bolts and open trunk.
Afugy is offline   Reply With Quote
Old 04-09-2011, 08:54 PM   #16
Jroc26
I got it, just took the rear deck speaker out, reached through and pulled the seat fold down strap and reached into the trunk and pulled the trunk popper, spoiler looks good on my car too. Thanks for the suggestions guys
Old 04-11-2011, 08:37 AM   #17
I was going to say you could try prayer...it was meant to keep people out! Glad you got it...lol!
Old 05-02-2011, 04:24 PM   #18
2fastshifter
2fastshifter's Avatar
2fastshifter is on a distinguished road
How much did they charge you for the spoiler?
and does it also has brakelights in it?
2fastshifter is offline   Reply With Quote
Old 05-04-2011, 05:45 AM   #19
Jroc26
$25 for the spoiler and no there is no brake light in it, its just the factory spoiler.
