Old 04-13-2011, 09:30 PM   #1
colonel6632
colonel6632's Avatar
fuel pump replacement
Hey guys, this is going go be short and sweet.
My fuel pump quit. I think this because I don't hear the hum from the tank, and have no pressure in my fuel rail.
Questions.
What is the easiest way to change it myself. Drop the tank or cut a hole in the floor?
And do I need any special tools other than basic wrenches and socket set.
I am looking to do this tomorrow after school. All help us appreciated
Old 04-13-2011, 10:04 PM   #2
Ttop191
Ttop191's Avatar
pull your rear seat out, there should be an access point that the pump is mounted to the bottom of
Old 04-13-2011, 10:06 PM   #3
^^ Nope it's not a Ford
Drop tank, get pump out
Old 04-13-2011, 10:08 PM   #4
Ttop191
Ttop191's Avatar
a lot of companies other than ford do this...I'm surprised the alero doesnt have it actually...
Old 04-13-2011, 10:28 PM   #5
some members have MADE a door there. but its definitely not standard.
I wish it was.
Old 04-13-2011, 10:55 PM   #6
colonel6632
thats what i meant, is it easier to just make a door, or is it easier to drop the tank. i have about 10l of fuel in it
Old 04-13-2011, 11:03 PM   #7
colonel6632
double post*
there is probably little chance that there is a broken wire correct?
i was driving along and then it just died.
Old 04-13-2011, 11:24 PM   #8
Greencoupe2.2
Greencoupe2.2's Avatar
Greencoupe2.2 is on a distinguished road
Try cleaning the connector next to the wheel well underneath the car.
Greencoupe2.2 is offline   Reply With Quote
Old 04-13-2011, 11:26 PM   #9
http://www.grandamgt.com/forum/showthread.php?t=83843
I love fuel pump threads
Old 04-14-2011, 01:59 AM   #10
Yeah, the W-Bodies have it....
Old 04-14-2011, 03:58 AM   #11
double post*
How did it die? Only one of the 3 pumps I had replaced died while I was driving. I was on a 35 MPH roadway, and the car started bucking a bit. I pulled over on a side street, stopped, then the car died.
The other 2 died when I started the car.
I'm on number 4 now
Old 04-14-2011, 08:54 AM   #12
colonel6632
died just the way you said. was driving along, car started bucking and barely running pulled over and then nothing
Old 10-27-2011, 05:49 PM   #13
Hellfire5670
Hellfire5670's Avatar
Hellfire5670 is on a distinguished road
so to change my pump do i have to drank my tank of gas? someone should make a how to... i might if i can get instructions on how to do this..
Hellfire5670 is offline   Reply With Quote
Old 10-27-2011, 06:17 PM   #14
foxsdaddy67
foxsdaddy67's Avatar
foxsdaddy67 is on a distinguished road
Send a message via Yahoo to foxsdaddy67
check your fuel pump relay under the hood!
foxsdaddy67 is offline   Reply With Quote
Old 10-27-2011, 09:09 PM   #15
colonel6632
i didnt drain my gas tank, mostly because my tank was already empty. its really easy to change the fuel pump. i found the hardest part was getting the fuel lines off
