Old 05-21-2011, 03:52 PM   #1
Brad Jahnke
adding transmission fluid
Can someone tell me where to add transmission fluid? I've searched the forums and nothing has come up. Is it the little red cap on the drivers side below the power steering?
Old 05-21-2011, 04:13 PM   #2
widbyj
widbyj's Avatar
Yep, that's the place. There is no dipstick and it's not good to put too much in... To check the level the car has to be up in the air, level, engine running and warmed up. There is a check plug where the passenger side driveshaft comes out of the transmission close to the engine. You remove that plug and then add trans fluid until it starts to leak out. Not a fun job...
If you are at 100K your trans is due for a filter change and fluid refill. Most people will have this done at a shop where they have the proper tools and experience. The whole oil pan on the trans has to come off to do the filter, usually a messy process. Good luck!
Old 05-21-2011, 11:23 PM   #3
^^ and it's an 11mm bolt.
I've checked my own, it was pretty easy, but I was working part time at a shop back then and I used a lift
Old 05-22-2011, 05:01 AM   #4
and if you pull out the plug and fluid comes out, its already good.
Old 05-22-2011, 10:38 AM   #5
unchained01
unchained01 is on a distinguished road
http://www.gaownersclub.com/forum/sh...d.php?t=133146 heres a great write with pics
unchained01 is offline   Reply With Quote
