Old 06-08-2011, 09:35 AM   #1
Alero779
Alero779's Avatar
Alero779 is on a distinguished road
Send a message via Skype™ to Alero779
Driver Side Window
I have a 2-Door 2003 Alero & the window just recently fell forward when I went to put it down today.. I removed the door panel & found that the little white clips that are siliconed to the bottom of the window have cracked and broken off (front & back) I tried an epoxy glue as a temporary fix to the problem but that proved in-effective. Bottom line is though, I was wondering if I would need a new window regulator and would it come with the 2 white clips for the bottom of the window?? I realize I sound like a total n00b at this but I was wondering if anyone has had a similar issue that was fixed..
Thanks
Ross
Alero779 is offline   Reply With Quote
Old 06-08-2011, 10:03 AM   #2
slownlow43
slownlow43's Avatar
slownlow43 is an unknown quantity at this point
I had this exact issue with my 02 4 door. Best solution I found was to go to a junkyard and get a new regulator and window for $75 total. IThe cheapest regulator I found new was around $110 because no one sold it without the window motor as well.
I'm a minitrucker-every build is a budget build
slownlow43 is offline   Reply With Quote
Old 06-08-2011, 10:10 AM   #3
Alero779
Alero779's Avatar
Thanks lownslow43, I didn't realize the window was sold with the regulator so maybe I'll have to do that then, gonna just buy new prolly lol :P
Old 06-08-2011, 10:14 AM   #4
nschmidt
nschmidt's Avatar
nschmidt is on a distinguished road
www.gmpartsdirect.com
Sash - Part #: 22689012
Clip - Part #: 22697622
This should be a little bit cheaper.
This is as long as your regulator/motor still works fine.
nschmidt is offline   Reply With Quote
Old 06-08-2011, 04:32 PM   #5
That01Olds
That01Olds's Avatar
That01Olds is on a distinguished road
I also recommend checking ebay for the part. Sometimes you can find it on there for cheaper. I remember when the Driver side window went on my Intrigue. I bought a brand new window regulator with the motor for about $30 or $40 off ebay.
That01Olds is offline   Reply With Quote
