06-11-2011, 11:16 PM
high millage thread
whats everyones millage on there alero? what kind of major repairs have you done?
ill start:
99 alero 2dr LD9. 138k when bought with new water pump
145k when sold (no major repairs)
GF currently driving (188k and no major repairs)
99 alero 2dr LA1 129k (did head gaskets and water pump)
130k currently
06-11-2011, 11:23 PM
'00 Alero 4DR LD9. bought at 111xxx
at 114xxx as of 6/11/11.
No major repairs
'00 Alero GL - 11X,XXX miles
-4500K/6000k/30000k(purple) HID's Hi/Lo/Fogs
-Carbon fiber pillars, door handles, and Gas cover
-Optima yellow top. This battery went end over end in my jeep (not strapped down) 13 times for 75 feet. and now is in my alero. one tough battery
-Cleared Corners/Painted Bezels
06-11-2011, 11:40 PM
I'm at 130,3xx
Did a water pump back around 128,xxx or so, and just at 130,000 I did both the upper and lower hoses.
A few LIMG jobs but I had the head gasket done last year in July about 120,000 miles
06-11-2011, 11:45 PM
Lol...2001 LD9 I Think...lets see...bought it with 66k
I've done:
Front hubs @ 89k
Ignition overhaul due to remote start failure @ 91k
Rack and pinion @94k
Front hubs again @97k
Blower motor @ 69k, 84k, 105k
2 tranny mounts, 1 engine mount @106k
A/C compressor @106k
I have a feeling the transmission is gonna need some work soon...
06-11-2011, 11:46 PM
i am up to 140,000 miles on my 3400
06-12-2011, 12:23 AM
My 2001 Alero GL 2.4L (LD9) had over 207k miles on it when my sister traded it in. I got it with 177k miles on it and drove it til 195k miles with no major repairs.
06-12-2011, 12:40 AM
00 ld9 with over 196k miles. wheel bearing once, second one in the garage for tomorrow. blower motor resistor, window motor reg, various other bits and pieces including a decent amount of rust repair, and an even more decent amount of custom work.
06-12-2011, 01:23 AM
99 2.4 had 109k when I bought it now has 116K, no major repairs just maintenance stuff and small minor things here and there.
06-12-2011, 04:33 AM
01' 3400. sitting at 167k miles.
repairs:
thermostat around 162k miles.
transmission rebuild around 148k-ish miles... (my fault.  )
pretty much it, love the car and no horrible issues.
Originally Posted by Oldsnut
Originally Posted by tipnitty
06-12-2011, 10:03 AM
2000 2.4L
my alero bought at 137k.
repairs done then since car was bought for $400,
one wheel bearing, one rear strut mount and rear sway bar bushings.
mileage now and repairs done.
152k
two wheel bearings in front, replaced abs harness on one side, quarter panels and some rockers, front pads and rotors new strut mounts all around except one, front sway bar links and one brake line.
I think thats everything I can't think of anything more that I needed to do to it. thankfully I can fix it all myself and it doesn't cost me a fortune
Reason: putting the year
06-12-2011, 10:40 AM
02 3400 GLS- bought with 67000km, blew the motor at 174000km, it sat in the driveway for 2 years and finally got replaced last year... other than that general maintenance and a couple wheel bearings
99 LD9- bought with 246000km for a bottle of tequila- replaced alternator and battery, did some bondo on the rockers, replaced all brakes- lines, rotors, pads, front calipers, did a GA interior swap and it now has 275000 with no issues (knock on wood!!)
06-12-2011, 10:57 AM
99 3400 bought with 152k, now has 154k lol. had a wheel bearing replaced, and needs blower motor resistor and cd player. (stock cd player takes a cd in, makes a god-awful noise and spits it back out)
06-12-2011, 11:01 AM
02 2.2 with 146k
back in jan/feb i had a misfire and had to replace the ignition module. $288 for part and labor.
P.S. did anyone catch the spelling in the title?
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
06-12-2011, 11:08 AM
251 000 km no repairs just very frequent oil changes and gas additives.
car runs like brand new no dents no rust.
06-12-2011, 11:12 AM
just rolled 200,000 day before yesterday pulling into work. only thing i`ve replaced is the p/s pump and a couple strut mounts. passenger side wheel bearing will be next week
06-12-2011, 04:05 PM
205,000 miles on my 3400.
so far the only really big thing needing to be done is a new cat converter.
also im pretty sure i need to replace the front calipers
06-12-2011, 04:36 PM
my last hoe had 189k before it broke, my new one has 157k on the cluster and the motor i swapped in has around 120
06-12-2011, 05:30 PM
2000 Alero GX, 2.4L
256,XXXkm, Purchased in November, only needed Front right Tie-rod to safety.
No Rust, No problems so far. Runs really strong
07-07-2011, 04:44 PM
1999 Alero GLS
156,000 Purchased March 04 (For Sale)
Front links and bushings replaced at 50k
Don't remember but the dealership might have done an intake or head gasket at 50k under warranty
Replaced left side wheel bearing 3 times right side once
replaced right strut recently because of broken spring
1 steering rack at 50k another around 80 or 90k
2 water pumps
right front caliper locked up and replaced
tie rod ends replaced twice on each side
Gas Gauge never really worked, even when i got it at 50k
Power steering pump replaced
Power steering lines replaced
http://rochester.craigslist.org/cto/2480673724.html
07-07-2011, 05:37 PM
2003 2dr. 38,000
03 Alero:
-47,xxx
