06-13-2011, 09:13 PM
how to replace belt....
Needing some help on replacing the belt to the engine.... I'm feeling pretty noobish, and can't find a how-to on this... But do I need to remove the engine mount that's right under the cruise control box? Seems that's the only way to get a new belt on.... So a little help would be awesome!
06-13-2011, 09:33 PM
which engine? go and rent a tensioner tool.
06-13-2011, 09:50 PM
yea you have to remove the mount, its stupid i know
06-13-2011, 09:54 PM
3400?
06-13-2011, 09:59 PM
yes, 3400. Sorry. lol
06-13-2011, 10:02 PM
⌘ Irish Pride
just cut it and glue it back together. no removal of engine mount!
Done lost my mind
06-13-2011, 10:18 PM
06-13-2011, 11:06 PM
You should have seen it earlier.... I was 99% sure I had to take that off... We cut the rest of the old belt off since it decided to shred up again... That's two belts in 3 months since my power steering issue this year... Anyways, this O'Reilly Auto employee comes out and said that we didn't need to remove that bracket to get it in.... He spent a good 20 minutes of our time trying to get it on and couldn't.... Was NOT following the diagram.... I tried telling him how it goes and he was all like, "I've put on hundreds of belts, and I never had to take an engine bracket off." Guy was a douche x10.
06-13-2011, 11:21 PM
lol well if there was a honda in the parking lot... it was his
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
yeah its a real pain in the a** on how us 3400 owners have to change our belt.
i mean... its not hard.. just annoying.
Originally Posted by Oldsnut
Originally Posted by tipnitty
06-13-2011, 11:23 PM
- Remove Cruise contorl box (gives you more room)
- jack up engine, put a block of wood between the jack head and oil pan Jack up until the car slightly raises
- put a thick screwdriver in the extra hole in the mount plates.
- remove 4 bolts on the plate (15mm I think)
- slide belt in
- Once belt is in, put everything back together
- put belt on eveything EXCEPT idler pulley
- open tensinor by pushing it back (3/8 drive head in hole in bottom of tensinor, if tensinor needs to be replaced, it's a 15mm bolt holding it on block)
- Slide belt under idler pulley and release tensinor
- Check belt by pushing on the parts futherest bewteen pulleys
- start engine
06-13-2011, 11:46 PM
Thanks man.
I figured it was a fairly simple job... Just wanted to make sure I do it right though.  It's MY first time actually changing the belt...
06-14-2011, 02:13 AM
Takes me about 20 minutes, taking my time to do it.
Be sure to do that screwdriver trick. I changed a belt once and my engine shifted during the process. I had my ex wife out there with me threading the bolts while I pulled the engine forward. All she did was complain that she shouldn't be threading bolts after giving birth 2 weeks prior, while I'm manually pulling a 300 lbs engine forward
The engine shifted because I used a trolley floor jack to hold the engine and it rolled a bit
06-14-2011, 07:43 AM
Well we took the bolts off without having something under there first... So the engine shifted a bit now... Wish we would have waited before doing anything.... But I was an hour away from home with limited tools... Getting it fixed today... We'll see how it goes...
06-14-2011, 02:43 PM
Got the belt on and drove it home. No problems, but when we got home, I looked at the belt and it's already looking worn out... Looked at everything and noticed the belt is not sitting on the harmonic balancer pulley. It's half on and half off in the back of the pulley. Could the pulley be bad, or is this a major problem happening?
Also, when I have the engine running, you can see the pulley move in and out a little...
06-14-2011, 02:58 PM
sounds loose, does it squeek?
06-14-2011, 03:32 PM
doesn't squeak or anything... To be honest, I really don't HEAR anything wrong with it, but then again, I'm not an expert. I could take a quick video of what it's doing...
06-14-2011, 03:53 PM
06-14-2011, 05:30 PM
06-14-2011, 08:54 PM
You have a bad pulley in there somewhere. That shouldn't happen
