07-15-2011, 08:40 PM
Reverse help!!
Ok so today somethin happened and now when i go in reverse there is anwierd crunching/scratching noise.. Does anyone know what this could be
99 alero
Pioneer stereo
Low budget
Mesh grille
2 12 inch pioneer subs
10 inch class D bazooka tube
07-15-2011, 10:01 PM
is ur ebrake engaged?
07-15-2011, 10:28 PM
Did you happen to go down any gravel roads or spin out on a gravel parking lot or something related to that?
07-15-2011, 11:20 PM
x2 on the Ebrake.
![[SIGPIC]](image.php?s=717f8430e737180e2d7cc733eb91360e&u=6730&type=sigpic&dateline=1339718145)
07-15-2011, 11:47 PM
If it only happens when he puts it in reverse i think it would be more then just an ebrake.
Originally Posted by Oldsnut
Originally Posted by tipnitty
07-16-2011, 12:21 AM
does it reverse smoothly, or does it shake or feel rough when reversing? Did it just start doing it suddenly, or did you do something and it started? DETAILS
07-16-2011, 12:55 AM
Run over your neighbor's cat?
07-16-2011, 03:55 AM
Are you describing an internal noise or is it just a blown trans/torque mount?
07-16-2011, 02:04 PM
Well i did go down a gravel road and spin the tires a lil bit and its a lil rough in reverse but not too bad
99 alero
Pioneer stereo
Low budget
Mesh grille
07-16-2011, 05:12 PM
Let's Play Army!
check your front brakes...did you wear them out to the point where they're just metal and the metal part of the pad is wedged between the rotor and the caliper, but not in the clips?
Originally Posted by black
07-19-2011, 08:15 PM
The reason I asked about the gravel road is because I drive down gravel roads a lot and one time my car started making a terrible grinding sound that appeared to be coming from the rear drivers side brake but only in reverse, it was quite in forward. I took off the tire and I found a quarter sized rock that had become lodged between the brake and some sort of shielding on the inside of the brake. for some reason it only made a sound in reverse.
I just thought I would tell you something that you could check out yourself without spending money on a mechanic first.
07-19-2011, 10:18 PM
when you say "go in reverse" do you mean as you put it in reverse or move in reverse?
07-19-2011, 10:49 PM
Move in reverse
99 alero
Pioneer stereo
Low budget
Mesh grille
07-19-2011, 11:48 PM
Its a midget caught between the brake pad and the rotor...see this all the time...only happens when they are wearing iron shorts.
07-20-2011, 12:40 AM
I heard of the midget thng before but never the iron shorts part
after more info has been provided, yes I concur with everybody that said possible gravel inside the rear wheels where the parking brakes are. Stop trying to be cool by doing awesome wheel spins on gravel. A guy on a Huffy can do that too ![Big Grin](http://www.aleromod.com/forums/images/smilies/biggrin.gif)
07-20-2011, 07:47 AM
^^^ lmao, ken.. so true.. however I have to admit that I used to do "awesome wheel spins in gravel"
