Old 07-17-2011, 03:27 AM   #1
mastershake
mastershake's Avatar
mastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond repute
flushing coolant
i'm planning on flushing the system in the next 2 weeks after this heat wave passes because the coolant smells fishy... and its orange..
so ive been doing research and ive concluded these are the correct steps (correct me if im wrong)
1. drain coolant via drainrooster or lower hose if the rooster is too difficult.
2. follow directions on prestone flush bottle, bleeding the system with each drain and refill.
3. drain all the rinse water out and add 50/50 prestone
what im wondering is.. if i use plain water to rinse the system and then drain via the radiator, wont there still be alot of water in the block/heater core when adding 50/50 coolant? i havent found much info on that so if someone could clear that up...
mastershake is offline   Reply With Quote
Old 07-17-2011, 08:08 PM   #2
mastershake
bump
Old 07-18-2011, 07:20 AM   #3
therory sounds good to me.
Old 07-18-2011, 06:20 PM   #4
mastershake
ok so i bought a bottle of peak instead of prestone because thats all autozone had, and it said to rinse the coolant out BEFORE putting the super flush in. problem is i accidentally put the flush in before rinsing out the excess coolant. with this be an issue? the prestones bottle says nothing about rinsing first but idk if the formulations are different
Old 08-31-2011, 09:43 PM   #5
Final500Alero309
Final500Alero309's Avatar
Final500Alero309 is on a distinguished road
I am also draining my coolant soon too. I was told dexcool will, eat away head gaskets and intake gaskets, because of its high acidity. Also tends to clog heater cores and coolant passages and was told regular green in instead of the GM dexcool
Final500Alero309 is offline   Reply With Quote
Old 08-31-2011, 09:46 PM   #6
zearchyo
zearchyo's Avatar
zearchyo is on a distinguished road
can anybody back this up
yeah right!
zearchyo is offline   Reply With Quote
Old 08-31-2011, 09:56 PM   #7
Final500Alero309
My dad who has been a technician for 25 years and has seen first hand on what dexcool has done to GM coolant systems, they said it is to last 100,000 but you are lucky if it lasts 50,000. If you wait until 100,00 it will be an brown/orange mud, and do the damage previously stated.
Old 08-31-2011, 10:39 PM   #8
mastershake
yup, when i flushed the dex out, little chunks of brown sludge came out with it. not sure if it was from a previous gasket problem or just the dex cool but i was glad i switched to green...
Old 08-31-2011, 10:52 PM   #9
Guys, I have to say, don't go green on this one. I know there have been threads going on the subject for years now. I have seen first hand on my other GA what the green does. head gasket went after using green for a few years, no biggie jsut put in new gaskets and Im off again. Not the case, teh green coolant had eaten "pocks" into the heads and the mating surface of the block. Huge mess to fix that one. I have seen many, and I mean many gaskets gone using the dex, and never the kind of damage we saw in mine. Stick with the Dex, just do it every 50-60K as suggested above and you'll not have any problems... well, no messed up heads anyway!
Old 08-31-2011, 11:56 PM   #10
zearchyo
zearchyo's Avatar
thats what i thought bc theres a reason y gm recoments it
yeah right!
Old 09-01-2011, 11:20 PM   #11
I plan on doing a full system flush soon new rad, thermo, hoses and running water through my coolent passages for a while dexcool has been know to penut butter up and leave chunks everywhere.
Old 09-02-2011, 07:07 AM   #12
usualy only happens when dexcool gets hot AND airaided. the leading cause is a low coolant.
