08-12-2011, 01:22 PM
Clutch is making weird noise in 1st and 2nd
Hi guys i have a 2.2L ecotec 5 speed and when im in first and second and accelerate ive noticed a loud clicking , somewhat grinding weird noise , but when i shift to 3rd it goes away.. the clutch still grabs fine and doesnt slip , any idea whats wrong ?
2002 Oldsmobile Alero GX 5 Speed
Stage 2 Clutch
Cosmo Racing Intake
Polyuruthane motor Mounts
Magnaflow Muffler
08-12-2011, 01:59 PM
ALSO , how Do I change the transmission fluid on my 5 spd Getrag transmission , ive heard this may fix the problem but I have no idea where to fill the transmission with fluid or where to empty it .
Stage 2 Clutch
Cosmo Racing Intake
Magnaflow Muffler
08-12-2011, 03:28 PM
Look right under the power steering fluid.. you gonna see a red cap in your transmission thats where you fill it. And to drain, right next to the frame on the lower driver side theres a bolt(is facing towards the wheel not down..), you need an allen key. Easy to change, remember our manual transmission uses ATF fluid, you need two qtz.
08-12-2011, 05:42 PM
the guy at wismers said 3.5L's , but your saying two ? i love your alero btw
Stage 2 Clutch
Cosmo Racing Intake
Magnaflow Muffler
08-12-2011, 08:17 PM
you are talking in a different unit of measure but i did the conversion
2 qt(US Liq) = 1.89270 L
08-13-2011, 04:40 PM
kinda sounds like a throwout bearing to me.
Originally Posted by Oldsnut
Originally Posted by tipnitty
08-13-2011, 04:45 PM
I second that too. The tranny is also known for making a growling noise, which is why ppl say change fluid and what not..after all nothing to worry about. I beat the shit out of mine.
08-13-2011, 10:52 PM
my transmission was also making growling and howling noises. it wasn't normal, and it wasn't good. throw out bearing was fine. my differential was shot, and it literally blew apart
08-19-2011, 02:10 AM
^PUT THE LUCAS OIL TRANNY FLUID ADITIVE IN THERE! it works wonders... But now that I think about it I'm sure if it's only for auto trannys or both... If it is, I very highly recamend it. And I think it was reddog that had a problem with his and it fixed it..
On a side note, I want he manual trans for mine ectotec for the win!
08-25-2011, 01:01 AM
Weird mines makes a grinding sound at low rpms. It get's quiet around 3k. It does it in 3rd if i short shift it.
08-25-2011, 09:47 AM
ya, when it's that far gone, you could run pure lucas oil additive, and it wouldn't of helped. i was blowing axle seals ever 2 weeks, it was howling and grinding and locking up.
it is mostly for autos, but i still run 1 bottle in my standard. been running it in there for 2 years
01-20-2012, 09:40 PM
Same here. i dont know what it is, and it kinda scares me. i know this thread is a few months old but to me its relevant
01-21-2012, 09:59 AM
I need to do my fluid. 01 at 120k. It has trouble going into 1st at times. I saw on Saturn Ion that you need to overfill the f23 also to get rid of the noise. Their is also a TSB about it.
01-21-2012, 11:53 AM
the engine in my alero has about 100 k on it, the tranny has 125K so i am probably in the same boat as you then. its also a 03 transmission. So i will check my fluids and hopefully i will be able to fix the noise. i dont like when the car is sad/angry. (any car)
01-21-2012, 12:28 PM
i highly recommend running lucas mobil 1 full synthetic atf. its quite expensive, but my transmission loves it, shifts so smooth. i also put 1 liter of lucas transmission additive
01-21-2012, 02:04 PM
^same
01-21-2012, 03:12 PM
http://shop.advanceautoparts.com/web...ntent=valu e4
is that what you mean by additive?
and you said lucas mobil 1? you mean Lucas or Mobile 1?- how much does the f23 take?
01-21-2012, 04:26 PM
sorry, ill explain better, my message was a little confusing
mobil 1 full synthetic transmission fluid.
lucas transmission additive.
and i put 2l in (1liter of each) but some people recommend 3.5 liters due to f23 noise. gm even put a bulletin out for it
01-21-2012, 04:56 PM
so ill just do like, 3 liters. to be safe i guess.
