Old 11-04-2011, 01:37 PM   #1
Opinions on Saturn SL2
Looking at a 1997 Saturn SL2,1.9l DOHC, body is in decent shape, runs well but has weak reverse and occasionally skips 2nd (P0732 - Gear 2 Incorrect ratio)
its throwing these 4 codes: only one of which really worries me.
P0302-Cylinder #2 Misfire (plugs, wires, coil...hopefully nothing big)
P0732-Gear 2 Incorrect ratio
P0141- down stream o2,not worried about it
P0133- up stream o2, not worried about it
EDIT: P0302, P0141, P0133 all FIXED! (cyl 2 plug wire loose. I love buying cars from girls LOL)
hoping p0732 is just low line pressure or simple fix.
going to check trans fuses for p0732 fix in a few mins.
its mine for $200 (has 214k) but runs perfect
Old 11-04-2011, 01:47 PM   #2
Yes! My girlfriends brother has one he bought it when he was 16 for like 1200 and it still runs today... Hes 23 now and it has like over 200k only major thing that happened was it broke the clutch cable.
Old 11-04-2011, 04:35 PM   #3
my ex had one, they are decent... she had a lot of problems on hers though.
Old 11-04-2011, 04:58 PM   #4
rocketfast321
rocketfast321's Avatar
rocketfast321 is on a distinguished road
Maybe this will healp
DTC P0732 Incorrect 2nd Gear Ratio
This is usually an indicator that the TORQUE CONVERTOR is NOT locking up when commanded by the PCM. First thing to check is the ELECTRICAL connector at the buss plate (on top of the transaxle) and then the FUSES to make sure they all have good connections. A weak alternator also often manifests itself first with poor transaxle shifting in lower gears.
Old Saturns never die, people KILL them, so check your damn oil!
Trouble Code: P0732 (3.5L V6 VIN 4 Auto)
A/T Additional Gear Ratio Error In Second Gear
Number of Trips to Set Code: 1
OBD II Monitor Type: CCM Details
Indicators: MIL Details
CCM Details
Trouble Code Conditions:
The transmission gear ratio is monitored continuously while the transmission is in gear. If the ratio of the Input RPM to the Output RPM does not match the current gear ratio, this DTC will set.
Possible Causes:
Related DTCs will be present
Transmission solenoid/pressure switch assembly has malfunctioned or failed
Internal transmission mechanical problems may exist
Intermittent gear ratio errors are present
rocketfast321 is offline   Reply With Quote
Old 11-04-2011, 10:58 PM   #5
For $200 you can always scrap it and make almost all of your money back. I'd do it in a heartbeat!
Old 11-07-2011, 10:27 AM   #6
zzyzzx
zzyzzx's Avatar
Around here Crazy Ray's advertises $300 for a car.
