No. I think its called that because few people knew about it originally, so it was sort of a secret. Its only for the 2.4, and its the intake cam from the ld2 engine which was the low output version of the 2.3l from thr early 90s. This cam has to be from 95 only because thats the only year that had the hex key hole for the p/s pump, and the exhaust cam from the lg0 which is the high output version of the engine, any year from i think 90-94. The intake cam is almost identical lift, but slightly longer duration, and the exhaust has more lift and duration.
