Old 12-04-2011, 02:38 AM   #1
Hellfire5670
Hellfire5670's Avatar
Hellfire5670 is on a distinguished road
Leaking Coolant
Well the other day i went to start my car and let it warm up and realized it wasn't warming so i came here for help and put coolant in it... now this morning i went and there was no heat again so i put even more coolant in cause it was and today after driving to work i heard a hissing sound coming from under the hood so i looked and it was coming from right below the throttle body so maybe i have a leak in between my Manifolds?
Hellfire5670 is offline   Reply With Quote
Old 12-04-2011, 10:41 AM   #2
sounds like LIMG (leaking intake manifold gasket) have you does a pressure test. is the coolant milky.
Old 12-04-2011, 03:39 PM   #3
Hellfire5670
To be honest i never see any coolant leaking :S nor is there any puddles
Old 12-04-2011, 03:46 PM   #4
mastershake
mastershake's Avatar
mastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond repute
a hissing sound may be a vacuum leak. if your car is eating coolant but it's not showing up outside the engine, it's probably leaking internally.
mastershake is offline   Reply With Quote
Old 12-05-2011, 07:15 AM   #5
check your coolant for anything but nice clear orange color.
check your oil for brown milky substance like a milkshake color.
check oil for being overfilled.
check your exhaust for excessive smoke/steam while running
do you smell coolant once your engine is hot?
Old 12-05-2011, 08:58 AM   #6
i would probably say limg as well... would it be possible that the gasket is bad enough to cause a vacuum leak there? that would also account for the hiss. how many miles are on your engine? and ^ what he said about all the oil checks, that will tell the story.
Old 12-05-2011, 12:35 PM   #7
Hellfire5670
well my mom put oil in my car while i was at work and overfilled it so my dad drained some and if there was a problem there he would have told me but her also said limg so ill get a new gasket and find this leak
OH! and its burning oil like crazy
Old 12-05-2011, 04:57 PM   #8
if your not looking for a problem you might miss a problem. also... oil burning is not a good sign. what makes you think its burning and not leaking? burning oil is when oil goes through the combustion chamber and out the tail pipe. a leak is an external oil leak that can get on the engine and smell like burning oil. theres a big difference between the two. LIMG can cause both a coolant leak (internal and external) and an oil leak.
Old 12-06-2011, 10:47 AM   #9
Hellfire5670
Then im sold its a LIMG and ill order one today
Old 12-06-2011, 12:47 PM   #10
zzyzzx
zzyzzx's Avatar
I also think it's a LIM gasket. Mine also leaked externally and I could idle the engine and watch it leak.
What year and how many miles on it?
I think I broke (probably more like shattered) a record here by finding my leak at around 26K miles. You probably have close to 100K miles like everyone else.
Old 12-07-2011, 08:28 PM   #11
Hellfire5670
Well i found a gasket set for head gasket and all gaskets up for 220 good deal?
was thinking i should do them all before something worse happens.. my friend was telling me my water pump too? its only 30 bucks and when i give mine back i get 30bucks back so why not?
