Old 12-22-2011, 03:57 PM   #1
Alero779
Alero779's Avatar
Alero779 is on a distinguished road
Send a message via Skype™ to Alero779
Proper LED Load Resistor Install
Hey guys I was wondering if u could answer a question I had. I recently bought and received some 60 SMD LED Switchback Turn Signals. I bought 50 watt (6OHM) inline load resistors and they didn't want to work both negative facing the bulb and positive so I took em out. I would like ti get rid of the hyperflash asap! Anyone know why they didn't work or if there is a trick, let me know as soon as u guys can!! (They were hooked up to the blue signal wires)
Thanks
Rosscoe
Alero779 is offline   Reply With Quote
Old 12-22-2011, 04:33 PM   #2
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Wait..so did you wire them in parallel with the bulb? Also are they for the front? The fronts are 3157s so one end of the resistor needs to go to the negative wire and one part needs to go to the turn signal wire.. not the running light part of the turn signal.. I can't remember what colour they are. If you have a haynes manual it'll help you find which color you need.
Old 12-22-2011, 06:17 PM   #3
Alero779
Alero779's Avatar
Wouldn't that drain the battery??
Old 12-22-2011, 08:19 PM   #4
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
No lol. Its equivalent to having the factory bulbs in there. The resistor is there to simulate the current draw effects of an incandesant light bulb because the LEDs have such a low current draw, your car thinks the bulb is out and thats why it hyperflashes.
Old 12-22-2011, 08:50 PM   #5
Alero779
Alero779's Avatar
Hyperflash
I just went to visit my mechanic (Lisenced for 36 years) and he told me to put the positive lead on the signal wire and the negative lead on the negative wire and the LED's work perfectly! I was not told to wire the lights this way because it wouldn't work.. I was told to splice into the signal wire positive facing down and negative facing the bulb, that doesn't make sense tho because there would be nothing for it to ground too.. Either way the problem is solved and the lights look amazing! I appreciate your input in trying to fix the issue though Have a Merry Christmas man and a Happy New Year!
Cheers
Rosscoe
Old 12-22-2011, 09:33 PM   #6
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Thats exactly what I said...
Old 12-22-2011, 11:29 PM   #7
^ya... What he said
Old 12-23-2011, 12:13 AM   #8
Alero779
Alero779's Avatar
Hyperflash
Hey guys lol thanks for the awesome illustration. Everything is working good though lol!!
Old 12-23-2011, 12:28 AM   #9
post some pictures!!!
Old 12-23-2011, 08:33 AM   #10
Mike The Canadian
Mike The Canadian is on a distinguished road
Damn you guys, you can actually have LED's in your tail lights lol
Mike The Canadian is offline   Reply With Quote
Old 12-23-2011, 10:29 AM   #11
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Lol can't your Malibu have them too?
Old 12-23-2011, 10:35 AM   #12
Mike The Canadian
Nah, bloody tail light is one pig tail that plugs into a giant circuit.
No seperate connectors for tail lights.
The kicker is that this stupid thing likes to let water in too
Old 12-23-2011, 11:29 PM   #13
so what do you do for bulbs? do you have to replace the entire circuit?
Old 12-24-2011, 02:32 AM   #14
Mike The Canadian
Nah, the bulbs can be removed separately, but you have no access to any individual wires. They click into the circuit itself.
