12-22-2011, 05:26 PM
Interior lights wont come on
So i took all my command start wires and crap out and went out today and my dash lights or any of those lights wont come on... I tried everything the fuses all check its only the interior dash/ ac control lights and the light under the shifter all other lights work ... Any help ?
12-22-2011, 06:08 PM
What?
You took out the wiring in your dash and can't figure out why it doesn't work?
12-22-2011, 06:17 PM
for the command start... i still have my remote for unlocking locking trunk and the alarm that works maybe i took a wire out :S whats the colors of the wires
12-22-2011, 07:38 PM
I wanna get this done before i have to drive to work tonight does anyone know?
12-22-2011, 09:05 PM
Have no idea what you are taking about. Don't know what a command wire is. If you mean a starter wire, they USED to use purple on GM cars, but I don't know if that's right for anything past 1990
I have wiring diagrams, but they are at home in my book and I'm at work right now
12-22-2011, 09:31 PM
Give him a break, he's from canada LOL. I think he means that he took out some wires and now his interior lights don't work? Maybe you should check the accessory wire.
12-22-2011, 10:36 PM
⌘ Irish Pride
Give this a try. see my last two posts
Done lost my mind
12-22-2011, 10:58 PM
I had put in command start in my car.
After it killed my starter i took the box that all the wires plugged into out.
I just took all the wires under my dash out that i had put in with the command start.
Now the lights wont work.
Better?
So im looking for a cut grey wire then? ill test the dimmer to see if power is going to it first if there is then its a cut grey wire?
if it isn't getting power its something before the dimmer
12-22-2011, 11:31 PM
Do they flash with the locking/unlocking of the vehical? If so you know they are still operable, if not well... Something got f*cked up in there.
12-22-2011, 11:39 PM
they don't come on at all none of them...
12-22-2011, 11:44 PM
⌘ Irish Pride
i never even cut the wires, I just tapped both wires and bridged em
Done lost my mind
12-22-2011, 11:45 PM
well something that collectively tells them to work isnt getting the signal. wire got messed up when you were working on it something?...
12-22-2011, 11:47 PM
Grey or brown.
I know brown to the radio goes to the parking lights. Grey goes to the cubby hole light and I think the gear selector light
