Old 03-25-2012, 10:14 PM   #1
Malibu369258
Malibu369258 is on a distinguished road
List of trouble codes that all showed up at once
Well haven't posted on here in ages, but finally have something to post/ask about. My girlfriend picked up a '99 Alero (3400 V6) about a month ago and a list of trouble codes popped up all at once.
Was wondering if there is a connection as to why all of this showed up at once... Car never had any codes before that.
The codes are as follows
C1223 Left Rear Wheel Speed Sensor Input Signal is 0
C1224 Right Rear Wheel Speed Sensor Input Signal is 0
C1225 Left Front Excessive Wheel Speed Variation
C1242 Pump Motor Circuit Open
C1286 Steering Sensor Bias Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
Malibu369258 is offline   Reply With Quote
Old 03-25-2012, 11:45 PM   #2
The P0101 would be worth investigating, hard to say with some of these codes, though. I've switched PCMs and programs many times and it seems some codes appear for no good reason. Changes were also made by GM to the programming for earlier models to correct drivability issues.
Here are some codes I get right now in my '99 that I can't account for:
Old 03-26-2012, 06:35 AM   #3
guiguilandry
guiguilandry's Avatar
look if there is corrosion in the EBCM connector...
Custom or Nothing...
www.demonautosport.ca
Old 03-31-2012, 11:31 AM   #4
Malibu369258
Well cleaned the MAF and put in a new air filter. Really needed it.
And bam the codes are all gone...
Old 03-31-2012, 07:57 PM   #5
guiguilandry
good for the last.... but for the first 5 codes it has nothing to do with them... and they were code that doesn't trigger the check engine light...
