Old 09-09-2004, 07:43 PM   #1
alerosport.com
Aiwa cdc x504mp <--- Has a AUX input on the display!
http://www.crutchfield.com/S-NbETZxLqXmH/c...cx504&s=0&cc=01
Andy at crutchfield tells me this
You are limited by the depth available (6.327") in your 1999 Oldsmobile Alero, and most of the aftermarket receivers are not listed as a good fit for this reason. You may be able to work around these depth limitations, but this will fall into the category of a custom installation and I'm afraid we can't be of much help there.
Of course, everything you purchase from Crutchfield comes with our unconditional 30 day, money back, Total Satisfaction Guarantee. You get a whole month to make sure you have the right equipment for your needs.
Im not sure if i would know how to do a custom fit?... If i did would the deck stick out more then normal?
Thanks for any help
Old 09-09-2004, 07:55 PM   #2
smokinAMD
It will fit after you cut some worthless black plastic junk out from behind your head unit.
Old 09-09-2004, 08:56 PM   #3
Youngblood77
Youngblood77's Avatar
Sometimes Crutchfield is right on the mark, other times they're way off. They said my Pioneer DEH-P6600 wouldn't fit, so when it came time for the install I came prepared with the dremel tool. As it turned-out, no cutting was needed. I'f that deck is what you want to have in your car, then it can be done...one way or another. Just make sure you got a decent dash kit, and the rest is just a little extra work. Get a dremel tool handy just in case.
Good Luck Alerosport ! Keep us posted, and we'll get that deck in there. :thumbsup:
Old 09-13-2004, 05:54 PM   #4
alerosport.com
Have the deck, waiting for the switch panel to arrive then ill tackle the project.
Old 09-13-2004, 06:30 PM   #5
BLK03GXS
BLK03GXS's Avatar
Dont worry about it just get a dremel lined up for when your going to do it...
My Alpine 7893 fits with a lil dremel work so any awia or Sony as they are more comenly known will fit. lol :P
Old 09-14-2004, 05:45 PM   #6
alerosport.com
Whats that mean?
Old 09-14-2004, 06:20 PM   #7
Crazytaxi37
The Dark Lord
Crazytaxi37's Avatar
Crazytaxi37 is an unknown quantity at this point
Send a message via AIM to Crazytaxi37
I also had to cut away the rear bracing because of depth problems. Without doing it my head unit would have stuck out about an inch. Not to tough to get around though.
Crazytaxi37 is offline   Reply With Quote
Old 09-15-2004, 02:37 PM   #8
1WhiteOSV
just about any single din deck will fit...as long as you have the mounting kit and wire harness (2 diff. ones: 1 if u got RDS or another if u dont)
Old 09-15-2004, 02:53 PM   #9
alerosport.com
Q.
How about do you take the trim/bezel around the radio? pull? or does any other trim moldings come off first?
A
Insert hand into cubby pull up and out, found out in my other fourm lol. Remove shifter trim piece first though.
Old 09-16-2004, 01:57 PM   #10
`2000redalero
haha totally off topic, but Andy's rule
1. me
2. Andy's Auto Sport
3. we now work at crutchfield
