Old 08-30-2012, 07:57 PM   #1
What size bolt?
What size bolt goes in the bottom of the throttle body?
I was cleaning the engine bay and noticed a bolt missing No vacuum leaks (at least that I know of) but I would like to replace this bolt.
Does anybody know the size of this bolt. I have a top bolt, but it's a different size
Old 08-30-2012, 08:16 PM   #2
i believe its either an 8mm or 10mm.
hit up a junkyard and take one from a GA or alero. stick it in your pocket, walk out...... hell its one bolt they might just give it to you for free.
Old 08-30-2012, 08:22 PM   #3
zearchyo
zearchyo's Avatar
zearchyo is on a distinguished road
yeah right!
zearchyo is offline   Reply With Quote
Old 08-30-2012, 10:28 PM   #4
should be M8-1.25 30-40mm, depending if you have stock or aftermarket TB
Old 01-13-2013, 09:36 PM   #5
MilzyZ34
MilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond repute
Send a message via AIM to MilzyZ34
M8x1.25 x40mm long would be the one to use. you wouldn't want to only have 5mm of thread howing because it would strip out. ideally you want 2x the diameter of threads when you thread into aluminum.
www.milzymotorsports.com
MilzyZ34 is offline   Reply With Quote
